Acknowledged
[Sim CRASH] Running on device that doesn't support wheelchair mode with mode set to true
SDK 6.4.1
Repro:
- Run an app on a device that supports wheelchair mode in the sim
- Turn on wheelchair mode
- Run app on a device that does not support wheelchair mode
>> crash
Translated Report (Full Report Below)
Process: simulator [47328]
Path: /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
Identifier: com.garmin.connectiq.simulator
Version: 6.4.1 (6.4.1)
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-12-22 09:17:15.0838 -0800
OS Version: macOS 14.1.2 (23B92)
Report Version: 12
Anonymous UUID: 5A18F4F2-35C0-936C-34A5-D2F176301C89
Sleep/Wake UUID: 47A78E03-C79D-4867-BE88-D781EE478513
Time Awake Since Boot: 960000 seconds
Time Since Wake: 10268 seconds
System Integrity Protection: enabled
Notes:
PC register does not match crashing frame (0x0 vs 0x100D110F3)
Crashed Thread: 29
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x2274686769656822 -> 0x0000686769656822 (possible pointer authentication failure)
Exception Codes: 0x0000000000000001, 0x2274686769656822
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [47328]
VM Region Info: 0x686769656822 is not in any region. Bytes after previous region: 114312322836515 Bytes before following region: 25616401995742
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
commpage (reserved) 1000000000-7000000000 [384.0G] ---/--- SM=NUL ...(unallocated)
---> GAP OF 0x7f43b1f00000 BYTES
MALLOC_LARGE 7fb3b1f00000-7fb3b20f0000 [ 1984K] rw-/rwx SM=PRV
Error Formulating Crash Report:
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_platform.dylib 0x7ff80ea7ca29 _platform_memmove$VARIANT$Rosetta + 361
1 CoreGraphics 0x7ff8144ae9b9 CGBlt_copyBytes + 521
2 CoreGraphics 0x7ff8149ce8b3 ARGB32_mark_image + 386
3 CoreGraphics 0x7ff81449abc0 ARGB32_image + 377
4 CoreGraphics 0x7ff8144894f8 ripl_Mark + 22
5 CoreGraphics 0x7ff8144894cf RIPLayerBltImage + 1087
6 CoreGraphics 0x7ff814488de3 ripc_RenderImage + 233
7 CoreGraphics 0x7ff81447dba4 ripc_DrawImage + 1092
8 CoreGraphics 0x7ff81447cf6b CGContextDrawImageWithOptions + 711
9 AppKit 0x7ff8121e06a9 __74-[NSImageRep drawInRect:fromRect:operation:fraction:respectFlipped:hints:]_block_invoke + 911
10 AppKit 0x7ff8121e01c9 -[NSImageRep drawInRect:fromRect:operation:fraction:respectFlipped:hints:] + 729
11 AppKit 0x7ff812774e55 __71-[NSImage drawInRect:fromRect:operation:fraction:respectFlipped:hints:]_block_invoke.1399 + 1035
12 AppKit 0x7ff8121bd2cc -[NSImage _usingBestRepresentationForRect:context:hints:body:] + 123
13 AppKit 0x7ff8121dfe45 -[NSImage drawInRect:fromRect:operation:fraction:respectFlipped:hints:] + 1513
14 simulator 0x1016f285c 0x100ca2000 + 10815580
15 simulator 0x1016e0191 0x100ca2000 + 10740113
16 simulator 0x10177b8f8 0x100ca2000 + 11376888
17 simulator 0x10177b5bc 0x100ca2000 + 11376060
18 simulator 0x100d01a14 0x100ca2000 + 391700
19 simulator 0x101639a0f 0x100ca2000 + 10058255
20 simulator 0x10163afba 0x100ca2000 + 10063802
21 simulator 0x10163ae50 0x100ca2000 + 10063440
22 simulator 0x10163b56c 0x100ca2000 + 10065260
23 simulator 0x10169ffe6 0x100ca2000 + 10477542
24 simulator 0x101734e16 0x100ca2000 + 11087382
25 simulator 0x101731f76 0x100ca2000 + 11075446
26 AppKit 0x7ff8121e298c _NSViewDrawRect + 121
27 AppKit 0x7ff812c7d483 -[NSView _recursive:displayRectIgnoringOpacity:inContext:stopAtLayerBackedViews:] + 1848
28 AppKit 0x7ff8121e20ba -[NSView(NSLayerKitGlue) _drawViewBackingLayer:inContext:drawingHandler:] + 747
29 AppKit 0x7ff8127a09af -[NSViewBackingLayer drawInContext:] + 64
30 AppKit 0x7ff8129cc123 -[NSViewBackingStore update:] + 509
31 AppKit 0x7ff81279f913 -[NSViewBackingLayerContents update:] + 43
32 AppKit 0x7ff8127a05ef -[NSViewBackingLayer display] + 1716
33 QuartzCore 0x7ff8174af295 CA::Layer::display_if_needed(CA::Transaction*) + 867
34 QuartzCore 0x7ff817647bc8 CA::Context::commit_transaction(CA::Transaction*, double, double*) + 758
35 QuartzCore 0x7ff817490455 CA::Transaction::commit() + 725
36 AppKit 0x7ff8121f328d __62+[CATransaction(NSCATransaction) NS_setFlushesWithDisplayLink]_block_invoke + 285
37 AppKit 0x7ff812cc3f59 ___NSRunLoopObserverCreateWithHandler_block_invoke + 41
38 CoreFoundation 0x7ff80eb26f0c __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
39 CoreFoundation 0x7ff80eb26e31 __CFRunLoopDoObservers + 493
40 CoreFoundation 0x7ff80eb263b3 __CFRunLoopRun + 850
41 CoreFoundation 0x7ff80eb25a99 CFRunLoopRunSpecific + 557
42 HIToolbox 0x7ff81988d9d9 RunCurrentEventLoopInMode + 292
43 HIToolbox 0x7ff81988d7e6 ReceiveNextEventCommon + 665
44 HIToolbox 0x7ff81988d531 _BlockUntilNextEventMatchingListInModeWithFilter + 66
45 AppKit 0x7ff812097885 _DPSNextEvent + 880
46 AppKit 0x7ff81298b348 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1304
47 AppKit 0x7ff812088dfa -[NSApplication run] + 603
48 simulator 0x10171648a 0x100ca2000 + 10962058
49 simulator 0x101615f9d 0x100ca2000 + 9912221
50 simulator 0x101587b0e 0x100ca2000 + 9329422
51 simulator 0x10155a423 0x100ca2000 + 9143331
52 simulator 0x1016d2a6a 0x100ca2000 + 10685034
53 simulator 0x1015bcc68 0x100ca2000 + 9546856
54 simulator 0x100ce42c2 0x100ca2000 + 271042
55 dyld 0x20211b3a6 start + 1942
Thread 1:: com.apple.rosetta.exceptionserver
0 runtime 0x7ff7ffc73294 0x7ff7ffc6f000 + 17044
Thread 2:
0 runtime 0x7ff7ffc9194c 0x7ff7ffc6f000 + 141644
Thread 3:
Thread 4:
Thread 5:
Thread 6:: com.apple.NSEventThread
0 ??? 0x7ff89ef02a78 ???
1 libsystem_kernel.dylib 0x7ff80ea0da6e mach_msg2_trap + 10
2 libsystem_kernel.dylib 0x7ff80ea1be7a mach_msg2_internal + 84
3 libsystem_kernel.dylib 0x7ff80ea14b92 mach_msg_overwrite + 653
4 libsystem_kernel.dylib 0x7ff80ea0dd5f mach_msg + 19
5 CoreFoundation 0x7ff80eb27b49 __CFRunLoopServiceMachPort + 143
6 CoreFoundation 0x7ff80eb265bc __CFRunLoopRun + 1371
7 CoreFoundation 0x7ff80eb25a99 CFRunLoopRunSpecific + 557
8 AppKit 0x7ff8121f4a00 _NSEventThread + 122
9 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
10 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
Thread 7:: TSK bkgd
1 libsystem_kernel.dylib 0x7ff80ea1060e __psynch_cvwait + 10
2 libsystem_pthread.dylib 0x7ff80ea4d76b _pthread_cond_wait + 1211
3 simulator 0x10142e94a 0x100ca2000 + 7915850
4 simulator 0x10142dc02 0x100ca2000 + 7912450
5 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
6 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
Thread 8:: NFM_Region_0
4 simulator 0x1014a3023 0x100ca2000 + 8392739
5 simulator 0x10142dc36 0x100ca2000 + 7912502
6 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
7 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
Thread 9:: IOPAppMain
4 simulator 0x1011a02a5 0x100ca2000 + 5235365
5 simulator 0x10142dc20 0x100ca2000 + 7912480
Thread 10:: ant_main
2 libsystem_pthread.dylib 0x7ff80ea4d79c _pthread_cond_wait + 1260
3 simulator 0x10142d6e0 0x100ca2000 + 7911136
4 simulator 0x10142e94a 0x100ca2000 + 7915850
5 simulator 0x101175445 0x100ca2000 + 5059653
6 simulator 0x10142dc20 0x100ca2000 + 7912480
7 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
8 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
Thread 11:: GPS main
Thread 12:: SNS main
Thread 13:: fit activity
4 simulator 0x1011df6f2 0x100ca2000 + 5494514
Thread 14:: ftm main
5 simulator 0x1011eed6f 0x100ca2000 + 5557615
Thread 15:: TVM main
5 simulator 0x1013d6a65 0x100ca2000 + 7555685
Thread 16:: TVM defrag
Thread 17:: parse main
4 simulator 0x100cc461b 0x100ca2000 + 140827
Thread 18:: GPX archive trk
4 simulator 0x1014b3f85 0x100ca2000 + 8462213
Thread 19:: URM Main
4 simulator 0x1011c2ab5 0x100ca2000 + 5376693
Thread 20:: mma sql bkg
Thread 21:: TLG main
5 simulator 0x1014b3dae 0x100ca2000 + 8461742
6 simulator 0x10142dc36 0x100ca2000 + 7912502
Thread 22:: libcurl Async H
4 simulator 0x1011bc545 0x100ca2000 + 5350725
Thread 23:: Download Manage
4 simulator 0x1011bea95 0x100ca2000 + 5360277
Thread 24:: Shell main
1 libsystem_kernel.dylib 0x7ff80ea1485e __accept + 10
2 simulator 0x1014aec82 0x100ca2000 + 8440962
3 simulator 0x1014aba87 0x100ca2000 + 8428167
4 simulator 0x10142dc20 0x100ca2000 + 7912480
Thread 25:
3 libc++.1.dylib 0x7ff80e9853c2 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
4 simulator 0x100d6d4d2 0x100ca2000 + 832722
5 simulator 0x100d6d3cf 0x100ca2000 + 832463
6 simulator 0x100d6d272 0x100ca2000 + 832114
Thread 26:
2 simulator 0x100dd044c 0x100ca2000 + 1238092
3 simulator 0x100da441c 0x100ca2000 + 1057820
4 simulator 0x101628f4c 0x100ca2000 + 9989964
5 simulator 0x1016289df 0x100ca2000 + 9988575
Thread 27:: Shell handler
3 simulator 0x10142d47c 0x100ca2000 + 7910524
4 simulator 0x100dcf9b4 0x100ca2000 + 1235380
5 simulator 0x1014ae9fa 0x100ca2000 + 8440314
6 simulator 0x1014adf53 0x100ca2000 + 8437587
7 simulator 0x1014ac3e7 0x100ca2000 + 8430567
8 simulator 0x10142dc20 0x100ca2000 + 7912480
Thread 28:
1 libsystem_kernel.dylib 0x7ff80ea11176 __recvfrom + 10
2 simulator 0x1014af061 0x100ca2000 + 8441953
3 simulator 0x1014adff2 0x100ca2000 + 8437746
4 simulator 0x100dcd03a 0x100ca2000 + 1224762
5 simulator 0x100dd498f 0x100ca2000 + 1255823
6 simulator 0x101628f4c 0x100ca2000 + 9989964
7 simulator 0x1016289df 0x100ca2000 + 9988575
8 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
9 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
Thread 29 Crashed:
0 simulator 0x100d110f3 0x100ca2000 + 454899
1 simulator 0x100dacc58 0x100ca2000 + 1092696
2 simulator 0x1013545ec 0x100ca2000 + 7022060
3 simulator 0x1013c1a47 0x100ca2000 + 7469639
4 simulator 0x10141adfe 0x100ca2000 + 7835134
5 simulator 0x10141e1df 0x100ca2000 + 7848415
6 simulator 0x10141e8fb 0x100ca2000 + 7850235
7 simulator 0x10141f60a 0x100ca2000 + 7853578
8 simulator 0x1013c257e 0x100ca2000 + 7472510
9 simulator 0x10140f706 0x100ca2000 + 7788294
10 simulator 0x100e2afbb 0x100ca2000 + 1609659
11 simulator 0x100ded66a 0x100ca2000 + 1357418
12 simulator 0x100dea82e 0x100ca2000 + 1345582
13 simulator 0x100dd498f 0x100ca2000 + 1255823
14 simulator 0x101628f4c 0x100ca2000 + 9989964
15 simulator 0x1016289df 0x100ca2000 + 9988575
16 libsystem_pthread.dylib 0x7ff80ea4d202 _pthread_start + 99
17 libsystem_pthread.dylib 0x7ff80ea48bab thread_start + 15
Thread 30:
Thread 29 crashed with X86 Thread State (64-bit):
rax: 0x2274686769656822 rbx: 0x0000000101dd5b00 rcx: 0x2274686769656822 rdx: 0x00007fb403100000
rdi: 0x00007fb40311e090 rsi: 0x00007fb40311e090 rbp: 0x0000000307da67d0 rsp: 0x0000000307da6770
r8: 0x00000000000001a0 r9: 0x00000000ffffff03 r10: 0x00000000ffffff03 r11: 0x00000000ffffff00
r12: 0x00007fb3d480cd40 r13: 0x0000000307da68b8 r14: 0x0000000307da68b0 r15: 0x00007fb3d480cd60
rip: <unavailable> rfl: 0x0000000000000207
tmp0: 0x0000000000000001 tmp1: 0x0000000000000000 tmp2: 0x0000000102102f2c
Binary Images:
0x202115000 - 0x2021b4fff dyld (*) <d5406f23-6967-39c4-beb5-6ae3293c7753> /usr/lib/dyld
0x10bdba000 - 0x10bdc9fff libobjc-trampolines.dylib (*) <7e101877-a6ff-3331-99a3-4222cb254447> /usr/lib/libobjc-trampolines.dylib
0x7ff7ffc6f000 - 0x7ff7ffc9efff runtime (*) <2c5acb8c-fbaf-31ab-aeb3-90905c3fa905> /usr/libexec/rosetta/runtime
0x10b5ea000 - 0x10b63dfff libRosettaRuntime (*) <a61ec9e9-1174-3dc6-9cdb-0d31811f4850> /Library/Apple/*/libRosettaRuntime
0x100ca2000 - 0x101c6dfff com.garmin.connectiq.simulator (6.4.1) <fcf28c9d-8e44-3e65-91f9-a76f0772e231> /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
0x7ff80ea77000 - 0x7ff80ea80fff libsystem_platform.dylib (*) <c94f952c-2787-30d2-ab77-ee474abd88d6> /usr/lib/system/libsystem_platform.dylib
0x7ff814445000 - 0x7ff814cd6ffc com.apple.CoreGraphics (2.0) <c709e588-6adf-33ad-b7c8-5dbe61c7694d> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7ff812059000 - 0x7ff81345effb com.apple.AppKit (6.9) <27fed5dd-d148-3238-bc95-1dac5dd57fa1> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7ff81748e000 - 0x7ff817835ff9 com.apple.QuartzCore (1.11) <a1fb38a4-9d16-3fa7-ac42-be6f87a69a7a> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7ff80eaac000 - 0x7ff80ef44ffc com.apple.CoreFoundation (6.9) <4d842118-bb65-3f01-9087-ff1a2e3ab0d5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff81985d000 - 0x7ff819af8ff4 com.apple.HIToolbox (2.1.1) <06bf0872-3b34-3c7b-ad5b-7a447d793405> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x7ff80ea0c000 - 0x7ff80ea46ff7 libsystem_kernel.dylib (*) <4df0d732-7fc4-3200-8176-f1804c63f2c8> /usr/lib/system/libsystem_kernel.dylib
0x7ff80ea47000 - 0x7ff80ea52fff libsystem_pthread.dylib (*) <c64722b0-e96a-3fa5-96c3-b4beaf0c494a> /usr/lib/system/libsystem_pthread.dylib
0x7ff80e974000 - 0x7ff80e9f2fff libc++.1.dylib (*) <b0f79a73-e705-38c8-a162-2465ed2adfaa> /usr/lib/libc++.1.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=681.5M resident=0K(0%) swapped_out_or_unallocated=681.5M(100%)
Writable regions: Total=1.5G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.5G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Activity Tracing 256K 1
CG image 5620K 27
CG raster data 4800K 4
ColorSync 236K 30
CoreAnimation 5548K 113
CoreGraphics 16K 3
CoreUI image data 916K 6
Dispatch continuations 96.0M 1
Foundation 16K 1
Kernel Alloc Once 8K 1
MALLOC 1.3G 65
MALLOC guard page 192K 12
Rosetta Arena 4096K 2
Rosetta Generic 1728K 429
Rosetta IndirectBranch 1024K 1
Rosetta JIT 128.0M 1
Rosetta Return Stack 600K 60
Rosetta Thread Context 600K 60
STACK GUARD 20K 5
Stack 22.8M 33
Stack Guard 56.1M 25
VM_ALLOCATE 9524K 19
VM_ALLOCATE (reserved) 4K 1 reserved VM address space (unallocated)
__CTF 824 1
__DATA 27.9M 423
__DATA_CONST 25.9M 257
__DATA_DIRTY 1046K 133
__FONT_DATA 2352 1
__LINKEDIT 145.1M 10
__OBJC_RO 70.7M 1
__OBJC_RW 2154K 2
__TEXT 536.5M 443
dyld private memory 260K 2
mapped file 7.1G 675
shared memory 1328K 17
unshared pmap 9792K 6
TOTAL 9.5G 2871
TOTAL, minus reserved VM space 9.5G 2871
Full Report
{"app_name":"simulator","timestamp":"2023-12-22 09:17:15.00 -0800","app_version":"6.4.1","slice_uuid":"fcf28c9d-8e44-3e65-91f9-a76f0772e231","build_version":"6.4.1","platform":1,"bundleID":"com.garmin.connectiq.simulator","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 14.1.2 (23B92)","roots_installed":0,"name":"simulator","incident_id":"B68B0FB8-BE5D-4F8A-BB1A-E8EA20D4DEC4"}
"uptime" : 960000,
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "Mac14,10",
"coalitionID" : 82812,
"osVersion" : {
"train" : "macOS 14.1.2",
"build" : "23B92",
"releaseType" : "User"
"captureTime" : "2023-12-22 09:17:15.0838 -0800",
"codeSigningMonitor" : 1,
"incident" : "B68B0FB8-BE5D-4F8A-BB1A-E8EA20D4DEC4",
"pid" : 47328,
"translated" : true,
"cpuType" : "X86-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2023-12-22 09:17:09.4427 -0800",
"procStartAbsTime" : 23060693914277,
"procExitAbsTime" : 23060829214721,
"procName" : "simulator",
"procPath" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
"bundleInfo" : {"CFBundleShortVersionString":"6.4.1","CFBundleVersion":"6.4.1","CFBundleIdentifier":"com.garmin.connectiq.simulator"},
"storeInfo" : {"deviceIdentifierForVendor":"3D59878A-5B4A-5D19-A690-441F57ACC310","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.garmin.connectiq.simulator",
"crashReporterKey" : "5A18F4F2-35C0-936C-34A5-D2F176301C89",
"codeSigningID" : "com.garmin.connectiq.simulator",
"codeSigningTeamID" : "72ES32VZUA",
"codeSigningFlags" : 570503953,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 4294967295,
"wakeTime" : 10268,
"sleepWakeUUID" : "47A78E03-C79D-4867-BE88-D781EE478513",
"sip" : "enabled",
"vmRegionInfo" : "0x686769656822 is not in any region. Bytes after previous region: 114312322836515 Bytes before following region: 25616401995742\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n commpage (reserved) 1000000000-7000000000 [384.0G] ---\/--- SM=NUL ...(unallocated)\n---> GAP OF 0x7f43b1f00000 BYTES\n MALLOC_LARGE 7fb3b1f00000-7fb3b20f0000 [ 1984K] rw-\/rwx SM=PRV ",
"exception" : {"codes":"0x0000000000000001, 0x2274686769656822","rawCodes":[1,2482724087947159586],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x2274686769656822 -> 0x0000686769656822 (possible pointer authentication failure)"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":47328},
"vmregioninfo" : "0x686769656822 is not in any region. Bytes after previous region: 114312322836515 Bytes before following region: 25616401995742\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n commpage (reserved) 1000000000-7000000000 [384.0G] ---\/--- SM=NUL ...(unallocated)\n---> GAP OF 0x7f43b1f00000 BYTES\n MALLOC_LARGE 7fb3b1f00000-7fb3b20f0000 [ 1984K] rw-\/rwx SM=PRV ",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 29,
"threads" : [{"id":9628683,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13001002672},"r12":{"value":18446744073709551615},"rosetta":{"tmp2":{"value":4778120816},"tmp1":{"value":37479},"tmp0":{"value":140705800728900}},"rbx":{"value":18446744073709551615},"r8":{"value":4793520032},"r15":{"value":18446744073709551615},"r10":{"value":18446744073709551615},"rdx":{"value":1364},"rdi":{"value":4791029628},"r9":{"value":18446744073709551615},"r13":{"value":18446744073709551615},"rflags":{"value":514},"rax":{"value":2400},"rsp":{"value":13001002624},"r11":{"value":18446744073709551615},"rcx":{"value":4791029760},"r14":{"value":18446744073709551615},"rsi":{"value":4793432388}},"queue":"com.apple.main-thread","frames":[{"imageOffset":23081,"symbol":"_platform_memmove$VARIANT$Rosetta","symbolLocation":361,"imageIndex":5},{"imageOffset":432569,"symbol":"CGBlt_copyBytes","symbolLocation":521,"imageIndex":6},{"imageOffset":5806259,"symbol":"ARGB32_mark_image","symbolLocation":386,"imageIndex":6},{"imageOffset":351168,"symbol":"ARGB32_image","symbolLocation":377,"imageIndex":6},{"imageOffset":279800,"symbol":"ripl_Mark","symbolLocation":22,"imageIndex":6},{"imageOffset":279759,"symbol":"RIPLayerBltImage","symbolLocation":1087,"imageIndex":6},{"imageOffset":277987,"symbol":"ripc_RenderImage","symbolLocation":233,"imageIndex":6},{"imageOffset":232356,"symbol":"ripc_DrawImage","symbolLocation":1092,"imageIndex":6},{"imageOffset":229227,"symbol":"CGContextDrawImageWithOptions","symbolLocation":711,"imageIndex":6},{"imageOffset":1603241,"symbol":"__74-[NSImageRep drawInRect:fromRect:operation:fraction:respectFlipped:hints:]_block_invoke","symbolLocation":911,"imageIndex":7},{"imageOffset":1601993,"symbol":"-[NSImageRep drawInRect:fromRect:operation:fraction:respectFlipped:hints:]","symbolLocation":729,"imageIndex":7},{"imageOffset":7454293,"symbol":"__71-[NSImage drawInRect:fromRect:operation:fraction:respectFlipped:hints:]_block_invoke.1399","symbolLocation":1035,"imageIndex":7},{"imageOffset":1458892,"symbol":"-[NSImage _usingBestRepresentationForRect:context:hints:body:]","symbolLocation":123,"imageIndex":7},{"imageOffset":1601093,"symbol":"-[NSImage drawInRect:fromRect:operation:fraction:respectFlipped:hints:]","symbolLocation":1513,"imageIndex":7},{"imageOffset":10815580,"imageIndex":4},{"imageOffset":10740113,"imageIndex":4},{"imageOffset":11376888,"imageIndex":4},{"imageOffset":11376060,"imageIndex":4},{"imageOffset":391700,"imageIndex":4},{"imageOffset":10058255,"imageIndex":4},{"imageOffset":10063802,"imageIndex":4},{"imageOffset":10063440,"imageIndex":4},{"imageOffset":10065260,"imageIndex":4},{"imageOffset":10477542,"imageIndex":4},{"imageOffset":11087382,"imageIndex":4},{"imageOffset":11075446,"imageIndex":4},{"imageOffset":1612172,"symbol":"_NSViewDrawRect","symbolLocation":121,"imageIndex":7},{"imageOffset":12731523,"symbol":"-[NSView _recursive:displayRectIgnoringOpacity:inContext:stopAtLayerBackedViews:]","symbolLocation":1848,"imageIndex":7},{"imageOffset":1609914,"symbol":"-[NSView(NSLayerKitGlue) _drawViewBackingLayer:inContext:drawingHandler:]","symbolLocation":747,"imageIndex":7},{"imageOffset":7633327,"symbol":"-[NSViewBackingLayer drawInContext:]","symbolLocation":64,"imageIndex":7},{"imageOffset":9908515,"symbol":"-[NSViewBackingStore update:]","symbolLocation":509,"imageIndex":7},{"imageOffset":7629075,"symbol":"-[NSViewBackingLayerContents update:]","symbolLocation":43,"imageIndex":7},{"imageOffset":7632367,"symbol":"-[NSViewBackingLayer display]","symbolLocation":1716,"imageIndex":7},{"imageOffset":135829,"symbol":"CA::Layer::display_if_needed(CA::Transaction*)","symbolLocation":867,"imageIndex":8},{"imageOffset":1809352,"symbol":"CA::Context::commit_transaction(CA::Transaction*, double, double*)","symbolLocation":758,"imageIndex":8},{"imageOffset":9301,"symbol":"CA::Transaction::commit()","symbolLocation":725,"imageIndex":8},{"imageOffset":1680013,"symbol":"__62+[CATransaction(NSCATransaction) NS_setFlushesWithDisplayLink]_block_invoke","symbolLocation":285,"imageIndex":7},{"imageOffset":13021017,"symbol":"___NSRunLoopObserverCreateWithHandler_block_invoke","symbolLocation":41,"imageIndex":7},{"imageOffset":503564,"symbol":"__CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__","symbolLocation":23,"imageIndex":9},{"imageOffset":503345,"symbol":"__CFRunLoopDoObservers","symbolLocation":493,"imageIndex":9},{"imageOffset":500659,"symbol":"__CFRunLoopRun","symbolLocation":850,"imageIndex":9},{"imageOffset":498329,"symbol":"CFRunLoopRunSpecific","symbolLocation":557,"imageIndex":9},{"imageOffset":199129,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":10},{"imageOffset":198630,"symbol":"ReceiveNextEventCommon","symbolLocation":665,"imageIndex":10},{"imageOffset":197937,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":66,"imageIndex":10},{"imageOffset":256133,"symbol":"_DPSNextEvent","symbolLocation":880,"imageIndex":7},{"imageOffset":9642824,"symbol":"-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":1304,"imageIndex":7},{"imageOffset":196090,"symbol":"-[NSApplication run]","symbolLocation":603,"imageIndex":7},{"imageOffset":10962058,"imageIndex":4},{"imageOffset":9912221,"imageIndex":4},{"imageOffset":9329422,"imageIndex":4},{"imageOffset":9143331,"imageIndex":4},{"imageOffset":10685034,"imageIndex":4},{"imageOffset":9546856,"imageIndex":4},{"imageOffset":271042,"imageIndex":4},{"imageOffset":25510,"symbol":"start","symbolLocation":1942,"imageIndex":0}]},{"id":9628685,"name":"com.apple.rosetta.exceptionserver","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":34097745362944},"r12":{"value":4329582380},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":4462471144243},"tmp0":{"value":10337986281472}},"rbx":{"value":4462471144243},"r8":{"value":7939},"r15":{"value":4362080256,"region":"<translation info unavailable>"},"r10":{"value":15586436317184},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":4494494592},"rflags":{"value":582},"rax":{"value":268451845},"rsp":{"value":10337986281472},"r11":{"value":2482724087947159586},"rcx":{"value":17314086914},"r14":{"value":4329582408},"rsi":{"value":2616}},"frames":[{"imageOffset":17044,"imageIndex":2}]},{"id":9628720,"frames":[{"imageOffset":141644,"imageIndex":2}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13001035776},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13001572352},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":8451},"r14":{"value":0},"rsi":{"value":0}}},{"id":9628721,"frames":[{"imageOffset":141644,"imageIndex":2}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13001592832},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13002129408},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":9731},"r14":{"value":0},"rsi":{"value":0}}},{"id":9628722,"frames":[{"imageOffset":141644,"imageIndex":2}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13002149888},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13002686464},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":19971},"r14":{"value":0},"rsi":{"value":0}}},{"id":9628762,"frames":[{"imageOffset":141644,"imageIndex":2}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13002706944},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13003243520},"rsp":{"value":409602},"r11":{"value":0},"rcx":{"value":19723},"r14":{"value":0},"rsi":{"value":0}}},{"id":9628802,"name":"com.apple.NSEventThread","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":190245576376320},"r12":{"value":4294967295},"rosetta":{"tmp2":{"value":140703374098042},"tmp1":{"value":140705795156840},"tmp0":{"value":18446744073709551615}},"rbx":{"value":190245576376320},"r8":{"value":0},"r15":{"value":190245576376320},"r10":{"value":190245576376320},"rdx":{"value":8589934592},"rdi":{"value":4294967295},"r9":{"value":190245576376320},"r13":{"value":21592279046},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":21592279046},"r14":{"value":2},"rsi":{"value":2}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":6766,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":12},{"imageOffset":65146,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":12},{"imageOffset":35730,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":12},{"imageOffset":7519,"symbol":"mach_msg","symbolLocation":19,"imageIndex":12},{"imageOffset":506697,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":143,"imageIndex":9},{"imageOffset":501180,"symbol":"__CFRunLoopRun","symbolLocation":1371,"imageIndex":9},{"imageOffset":498329,"symbol":"CFRunLoopRunSpecific","symbolLocation":557,"imageIndex":9},{"imageOffset":1686016,"symbol":"_NSEventThread","symbolLocation":122,"imageIndex":7},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628803,"name":"TSK bkgd","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13004316672},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":7912450,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628804,"name":"NFM_Region_0","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":6144},"r10":{"value":0},"rdx":{"value":6144},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":26392574040320},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":256},"rcx":{"value":0},"r14":{"value":13004853248},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":8392739,"imageIndex":4},{"imageOffset":7912502,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628805,"name":"IOPAppMain","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13005389824},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":5235365,"imageIndex":4},{"imageOffset":7912480,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628806,"name":"ant_main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":249946000},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":512},"r10":{"value":0},"rdx":{"value":512},"rdi":{"value":249946000},"r9":{"value":65704},"r13":{"value":26392574040320},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":6400},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26524,"symbol":"_pthread_cond_wait","symbolLocation":1260,"imageIndex":13},{"imageOffset":7911136,"imageIndex":4},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":5059653,"imageIndex":4},{"imageOffset":7912480,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628807,"name":"GPS main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13006462976},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":7912450,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628808,"name":"SNS main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13006999552},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":7912450,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628809,"name":"fit activity","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13007536128},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":5494514,"imageIndex":4},{"imageOffset":7912480,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628810,"name":"ftm main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":998884000},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":13008071120},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":998884000},"r9":{"value":65704},"r13":{"value":6601364735744},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":1792},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26524,"symbol":"_pthread_cond_wait","symbolLocation":1260,"imageIndex":13},{"imageOffset":7911136,"imageIndex":4},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":5557615,"imageIndex":4},{"imageOffset":7912480,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628811,"name":"TVM main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":999253000},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":4495717888},"r15":{"value":4608},"r10":{"value":0},"rdx":{"value":4608},"rdi":{"value":999253000},"r9":{"value":65704},"r13":{"value":19795504272128},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":768},"rcx":{"value":0},"r14":{"value":4864},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26524,"symbol":"_pthread_cond_wait","symbolLocation":1260,"imageIndex":13},{"imageOffset":7911136,"imageIndex":4},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":7555685,"imageIndex":4},{"imageOffset":7912480,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628812,"name":"TVM defrag","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13009145856},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":7912450,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628821,"name":"parse main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13009682432},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":140827,"imageIndex":4},{"imageOffset":7912480,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628822,"name":"GPX archive trk","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13010219008},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":8462213,"imageIndex":4},{"imageOffset":7912480,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628823,"name":"URM Main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13010755584},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":5376693,"imageIndex":4},{"imageOffset":7912480,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628824,"name":"mma sql bkg","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13011292160},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":7912450,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628829,"name":"TLG main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":999252000},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":13012364936},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":999252000},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":512},"rsi":{"value":52970}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26524,"symbol":"_pthread_cond_wait","symbolLocation":1260,"imageIndex":13},{"imageOffset":7911136,"imageIndex":4},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":8461742,"imageIndex":4},{"imageOffset":7912502,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628830,"name":"libcurl Async H","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13012901888},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":5350725,"imageIndex":4},{"imageOffset":7912502,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628831,"name":"Download Manage","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13013438464},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7915850,"imageIndex":4},{"imageOffset":5360277,"imageIndex":4},{"imageOffset":7912502,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628832,"name":"Shell main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":2181038079},"r12":{"value":140411103417192},"rosetta":{"tmp2":{"value":140703374067796},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":140410852758064},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":4326837080},"r9":{"value":2181038079},"r13":{"value":4326836704},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":270},"r11":{"value":2147483648},"rcx":{"value":0},"r14":{"value":4326836832},"rsi":{"value":140410852753600}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":34910,"symbol":"__accept","symbolLocation":10,"imageIndex":12},{"imageOffset":8440962,"imageIndex":4},{"imageOffset":8428167,"imageIndex":4},{"imageOffset":7912480,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628833,"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":70594,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":14},{"imageOffset":832722,"imageIndex":4},{"imageOffset":832463,"imageIndex":4},{"imageOffset":832114,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":160},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13014511616},"rsi":{"value":0}}},{"id":9628834,"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":34910,"symbol":"__accept","symbolLocation":10,"imageIndex":12},{"imageOffset":1238092,"imageIndex":4},{"imageOffset":1057820,"imageIndex":4},{"imageOffset":9989964,"imageIndex":4},{"imageOffset":9988575,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":140411383316480},"r12":{"value":4309271728},"rosetta":{"tmp2":{"value":140703374067796},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":13015047560},"r8":{"value":13015047696},"r15":{"value":4326279928},"r10":{"value":13015047560},"rdx":{"value":0},"rdi":{"value":140410302836816},"r9":{"value":140411383316480},"r13":{"value":13015048192},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":1},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":140410302836816},"rsi":{"value":140410302836752}}},{"id":9628941,"name":"Shell handler","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703374050820},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703374307789,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13015584768},"rsi":{"value":0}},"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":17934,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":12},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":13},{"imageOffset":7910524,"imageIndex":4},{"imageOffset":1235380,"imageIndex":4},{"imageOffset":8440314,"imageIndex":4},{"imageOffset":8437587,"imageIndex":4},{"imageOffset":8430567,"imageIndex":4},{"imageOffset":7912480,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628942,"frames":[{"imageOffset":140705795156600,"imageIndex":11},{"imageOffset":20854,"symbol":"__recvfrom","symbolLocation":10,"imageIndex":12},{"imageOffset":8441953,"imageIndex":4},{"imageOffset":8437746,"imageIndex":4},{"imageOffset":1224762,"imageIndex":4},{"imageOffset":1255823,"imageIndex":4},{"imageOffset":9989964,"imageIndex":4},{"imageOffset":9988575,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":0},"r12":{"value":12},"rosetta":{"tmp2":{"value":140703374053740},"tmp1":{"value":140705795156556},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":13016120604},"r15":{"value":140410854854976},"r10":{"value":0},"rdx":{"value":12},"rdi":{"value":140410854855024},"r9":{"value":0},"r13":{"value":13016120577},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":140410854855024},"rsi":{"value":140410854854976}}},{"triggered":true,"id":9628962,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13016655824},"r12":{"value":140410341084480},"rosetta":{"tmp2":{"value":4329582380},"tmp1":{"value":0},"tmp0":{"value":1}},"rbx":{"value":4326251264},"r8":{"value":416},"r15":{"value":140410341084512},"r10":{"value":4294967043},"rdx":{"value":140411122221056},"rdi":{"value":140411122344080},"r9":{"value":4294967043},"r13":{"value":13016656056},"rflags":{"value":519},"rax":{"value":2482724087947159586},"rsp":{"value":13016655728},"r11":{"value":4294967040},"rcx":{"value":2482724087947159586},"r14":{"value":13016656048},"rsi":{"value":140411122344080}},"frames":[{"imageOffset":454899,"imageIndex":4},{"imageOffset":1092696,"imageIndex":4},{"imageOffset":7022060,"imageIndex":4},{"imageOffset":7469639,"imageIndex":4},{"imageOffset":7835134,"imageIndex":4},{"imageOffset":7848415,"imageIndex":4},{"imageOffset":7850235,"imageIndex":4},{"imageOffset":7853578,"imageIndex":4},{"imageOffset":7472510,"imageIndex":4},{"imageOffset":7788294,"imageIndex":4},{"imageOffset":1609659,"imageIndex":4},{"imageOffset":1357418,"imageIndex":4},{"imageOffset":1345582,"imageIndex":4},{"imageOffset":1255823,"imageIndex":4},{"imageOffset":9989964,"imageIndex":4},{"imageOffset":9988575,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":13},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":13}]},{"id":9628972,"frames":[{"imageOffset":141644,"imageIndex":2}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13016682496},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13017219072},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":95763},"r14":{"value":0},"rsi":{"value":0}}}],
"usedImages" : [
"source" : "P",
"arch" : "x86_64",
"base" : 8624623616,
"size" : 655360,
"uuid" : "d5406f23-6967-39c4-beb5-6ae3293c7753",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"source" : "P",
"arch" : "x86_64",
"base" : 4493910016,
"size" : 65536,
"uuid" : "7e101877-a6ff-3331-99a3-4222cb254447",
"path" : "\/usr\/lib\/libobjc-trampolines.dylib",
"name" : "libobjc-trampolines.dylib"
"source" : "P",
"arch" : "arm64",
"base" : 140703124877312,
"size" : 196608,
"uuid" : "2c5acb8c-fbaf-31ab-aeb3-90905c3fa905",
"path" : "\/usr\/libexec\/rosetta\/runtime",
"name" : "runtime"
"source" : "P",
"arch" : "arm64",
"base" : 4485718016,
"size" : 344064,
"uuid" : "a61ec9e9-1174-3dc6-9cdb-0d31811f4850",
"path" : "\/Library\/Apple\/*\/libRosettaRuntime",
"name" : "libRosettaRuntime"
"source" : "P",
"arch" : "x86_64",
"base" : 4308213760,
"CFBundleShortVersionString" : "6.4.1",
"CFBundleIdentifier" : "com.garmin.connectiq.simulator",
"size" : 16564224,
"uuid" : "fcf28c9d-8e44-3e65-91f9-a76f0772e231",
"path" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
"name" : "simulator",
"CFBundleVersion" : "6.4.1"
"source" : "P",
"arch" : "x86_64",
"base" : 140703374471168,
"size" : 40960,
"uuid" : "c94f952c-2787-30d2-ab77-ee474abd88d6",
"path" : "\/usr\/lib\/system\/libsystem_platform.dylib",
"name" : "libsystem_platform.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703468638208,
"CFBundleShortVersionString" : "2.0",
"CFBundleIdentifier" : "com.apple.CoreGraphics",
"size" : 8986621,
"uuid" : "c709e588-6adf-33ad-b7c8-5dbe61c7694d",
"path" : "\/System\/Library\/Frameworks\/CoreGraphics.framework\/Versions\/A\/CoreGraphics",
"name" : "CoreGraphics",
"CFBundleVersion" : "1774.1.12"
"source" : "P",
"arch" : "x86_64",
"base" : 140703430971392,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 20996092,
"uuid" : "27fed5dd-d148-3238-bc95-1dac5dd57fa1",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2487.20.107"
"source" : "P",
"arch" : "x86_64",
"base" : 140703519268864,
"CFBundleShortVersionString" : "1.11",
"CFBundleIdentifier" : "com.apple.QuartzCore",
"size" : 3833850,
"uuid" : "a1fb38a4-9d16-3fa7-ac42-be6f87a69a7a",
"path" : "\/System\/Library\/Frameworks\/QuartzCore.framework\/Versions\/A\/QuartzCore",
"name" : "QuartzCore",
"CFBundleVersion" : "1109.3"
"source" : "P",
"arch" : "x86_64",
"base" : 140703374688256,
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 4820989,
"uuid" : "4d842118-bb65-3f01-9087-ff1a2e3ab0d5",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "2106"
"source" : "P",
"arch" : "x86_64",
"base" : 140703556816896,
"CFBundleShortVersionString" : "2.1.1",
"CFBundleIdentifier" : "com.apple.HIToolbox",
"size" : 2736117,
"uuid" : "06bf0872-3b34-3c7b-ad5b-7a447d793405",
"path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
"name" : "HIToolbox"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "x86_64",
"base" : 140703374032896,
"size" : 241656,
"uuid" : "4df0d732-7fc4-3200-8176-f1804c63f2c8",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703374274560,
"size" : 49152,
"uuid" : "c64722b0-e96a-3fa5-96c3-b4beaf0c494a",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703373410304,
"size" : 520192,
"uuid" : "b0f79a73-e705-38c8-a162-2465ed2adfaa",
"path" : "\/usr\/lib\/libc++.1.dylib",
"name" : "libc++.1.dylib"
"sharedCache" : {
"base" : 140703369871360,
"size" : 21474836480,
"uuid" : "926a5dba-1202-3711-9462-94bb6fd43274"
"vmSummary" : "ReadOnly portion of Libraries: Total=681.5M resident=0K(0%) swapped_out_or_unallocated=681.5M(100%)\nWritable regions: Total=1.5G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.5G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nActivity Tracing 256K 1 \nCG image 5620K 27 \nCG raster data 4800K 4 \nColorSync 236K 30 \nCoreAnimation 5548K 113 \nCoreGraphics 16K 3 \nCoreUI image data 916K 6 \nDispatch continuations 96.0M 1 \nFoundation 16K 1 \nKernel Alloc Once 8K 1 \nMALLOC 1.3G 65 \nMALLOC guard page 192K 12 \nRosetta Arena 4096K 2 \nRosetta Generic 1728K 429 \nRosetta IndirectBranch 1024K 1 \nRosetta JIT 128.0M 1 \nRosetta Return Stack 600K 60 \nRosetta Thread Context 600K 60 \nSTACK GUARD 20K 5 \nStack 22.8M 33 \nStack Guard 56.1M 25 \nVM_ALLOCATE 9524K 19 \nVM_ALLOCATE (reserved) 4K 1 reserved VM address space (unallocated)\n__CTF 824 1 \n__DATA 27.9M 423 \n__DATA_CONST 25.9M 257 \n__DATA_DIRTY 1046K 133 \n__FONT_DATA 2352 1 \n__LINKEDIT 145.1M 10 \n__OBJC_RO 70.7M 1 \n__OBJC_RW 2154K 2 \n__TEXT 536.5M 443 \ndyld private memory 260K 2 \nmapped file 7.1G 675 \nshared memory 1328K 17 \nunshared pmap 9792K 6 \n=========== ======= ======= \nTOTAL 9.5G 2871 \nTOTAL, minus reserved VM space 9.5G 2871 \n",
"legacyInfo" : {
"threadTriggered" : {
"logWritingSignature" : "efff20ab6ac0e619d99eea3e73fac403155bebae",
"trialInfo" : {
"rollouts" : [
"rolloutId" : "64b21a7351cbb02ce3442e4e",
"factorPackIds" : {
"REMINDERS_GROCERY" : "65542c604a6560536bdb1d22"
"deploymentId" : 240000032
"rolloutId" : "63f9578e238e7b23a1f3030a",
"factorPackIds" : {
"deploymentId" : 240000005
"experiments" : [
"reportNotes" : [
"PC register does not match crashing frame (0x0 vs 0x100D110F3)"
Model: Mac14,10, BootROM 10151.41.12, proc 12:8:4 processors, 32 GB, SMC
Graphics: Apple M2 Pro, Apple M2 Pro, Built-In
Display: Color LCD, 3456 x 2234 Retina, Main, MirrorOff, Online
Display: HS156KN, 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition), MirrorOff, Online
Memory Module: LPDDR5, Micron
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4388), wl0: Sep 1 2023 19:33:37 version 23.10.765.4.41.51.121 FWID 01-e2f09e46
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
Thunderbolt Bus: MacBook Pro, Apple Inc.
