Ticket Created
WERETECH-11175
set/getProperty deprecate on sdk 4?
In current doc something has changed!!
Previous information: some function (e.g. deleteProperty) was planned to remove but not set/get.
My app run well and there are values in sim Application.AppBase.Data.
So, is documentation correct?
I have some strange app behaviour on sim:
- settings don't change
- memory peaks
- console  message "Unable to serialize app data"
- resetting settings to default
can be connected with any changes in sdk 4?
Parents
  • > It'll be removed form CIQ on devices so it'll be possible to compile code with set/getProporty with sdk >4 for devices with ciq <4, correct?
    The functions would not exist for devices with ConnectIQ 5.x (System 6) support, but would exist for earlier devices. i.e., we would leave existing devices as-is (simulated and physical devices), and future devices would just not have those functions at all.
    The easiest way around this is to have a wrapper that is conditionally compiled. You can use build exclusions to select which file/function is compiled in for each device.
    // source-classicStorage/MyStorage.mc
    module MyStorage
        var _theApp;
        function _getApp() {
            if (_theApp == null) {
                _theApp = Application.getApp();
            return _theApp;
        function getValue(key) {
            return _getApp().getProperty(key);
        function setValue(key, val) {
            return _getApp().setProperty(key, val);
        function deleteValue(key) {
            return _getApp().deleteProperty(key);
        function clearValues() {
            return _theApp().clearProperties();
    // source-modernStorage/MyStorage.mc
    module MyStorage
            return Storage.getValue(key);
            return Storage.setValue(key, val);
            return Storage.deleteValue(key);
            return Storage.clearValues();
    // default.jungle
    project.manifest = manifest.xml
    # devices that do not have Application.Storage module go here
    vivoactive_hr.sourcePath = $(vivoactive_hr.sourcePath);source-classicStorage
    # devices that do have Application.Storage module go here
    fenix6.sourcePath = $(fenix6.sourcePath);source-modernStorage
Comment
    module MyStorage
        var _theApp;
            return _theApp;
    module MyStorage
    // default.jungle
Children
  • o time I have enough memory (especially you suggest class, members and consumption memory too)  I prefer not to mix in jungle, my solution:
        function setPrp(k, v)
            if(APP has :Storage)
                APP.Storage.setValue(k, v);
            }else
                APP.getApp().setProperty(k, v);
        function getPrp(k)
                return APP.Storage.getValue(k);
            }else
                return APP.getApp().getProperty(k);
