Hi,
I raised this on the forum yesterday, but the post has mysteriously disappeared.
I receive the following error when trying to build two of my more complex apps (multiple source code files and more complex jungles) - the error output from one of them is below.
I am running macos v11.2.3 (with java v1.8.0_271-b09)
VS Code 1.54.3 with Monkey C extension 0.1.10
CIQ 4.0.1
all of my apps compile/build successfully when the Monkey C Type Check Level is set to "default". any other setting (Gradual, Informative or Strict) produces the following output. I expect my apps to fail as I have not updated them to support the new Types scaffolding, but I wasn't expecting an error from the compiler in the manner produced.
I can provide one of my CIQ projects if required.
> Executing task in folder TrainingHR: java -Xms768m -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar /Users/rda/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.0.1-2021-04-21-1bb58d97e/bin/monkeybrains.jar -o bin/TrainingHR.prg -f /Users/rda/OneDrive/Home/GarminConnect/gitRepos/TrainingHR/monkey.jungle -y /Users/rda/OneDrive/Home/GarminConnect/developer_key -w -l 3 -d edge530_sim <
ERROR: Unresolved type
com.garmin.monkeybrains.compiler2.CompilerException: Unresolved type
at com.garmin.monkeybrains.compiler2.typechecker.FunctionTypeChecker.getTypeName(FunctionTypeChecker.java:431)
at com.garmin.monkeybrains.compiler2.typechecker.FunctionTypeChecker.test(FunctionTypeChecker.java:1289)
at com.garmin.monkeybrains.compiler2.typechecker.FunctionTypeChecker.testNode(FunctionTypeChecker.java:467)
at com.garmin.monkeybrains.compiler2.typechecker.FunctionTypeChecker.process(FunctionTypeChecker.java:243)
at com.garmin.monkeybrains.compiler2.TypeChecker.processFunction(TypeChecker.java:234)
at com.garmin.monkeybrains.compiler2.TypeChecker.processModule(TypeChecker.java:199)
at com.garmin.monkeybrains.compiler2.TypeChecker.processModule(TypeChecker.java:197)
at com.garmin.monkeybrains.compiler2.TypeChecker.runTypeChecker(TypeChecker.java:103)
at com.garmin.monkeybrains.ProjectBuilder.runCompiler2(ProjectBuilder.java:553)
at com.garmin.monkeybrains.Monkeybrains.runPRGCompiler(Monkeybrains.java:1542)
at com.garmin.monkeybrains.Monkeybrains.compileApplication(Monkeybrains.java:1264)
at com.garmin.monkeybrains.Monkeybrains.run(Monkeybrains.java:2672)
at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:322)
at com.garmin.monkeybrains.Monkeybrains.main(Monkeybrains.java:351)
usage: monkeyc [-a <arg>] [-b <arg>] [-c <arg>] [-d <arg>] [-e]
[--Eno-invalid-symbol] [-f <arg>] [-g] [-h] [-i <arg>] [-l <arg>] [-m
<arg>] [-o <arg>] [-p <arg>] [-r] [-s <arg>] [-t] [-u <arg>] [-v] [-w]
[-x <arg>] [-y <arg>] [-z <arg>]
-a,--apidb <arg> API import file
-b,--apimir <arg> API MIR file
-c,--api-level <arg> API Level to target
-d,--device <arg> Target device
-e,--package-app Create an application package.
--Eno-invalid-symbolDo not error when a symbol is found to be invalid
-f,--jungles <arg> Jungle files
-g,--debug Print debug output
-h,--help Prints help information
-i,--import-dbg <arg> Import api.debug.xml
-l,--typecheck <arg> Type check [0=off, 1=gradual, 2=informative, 3=strict]
-m,--manifest <arg> Manifest file (deprecated)
-o,--output <arg> Output file to create
-p,--project-info <arg>projectInfo.xml file to use when compiling
-r,--release Strip debug information
-s,--sdk-version <arg> SDK version to target (deprecated, use -c
-t,--unit-test Enables compilation of unit tests
-u,--devices <arg> devices.xml file to use when compiling (deprecated)
-v,--version Prints the compiler version
-w,--warn Show compiler warnings
-x,--excludes <arg> Add annotations to the exclude list (deprecated)
-y,--private-key <arg> Private key to sign builds with
-z,--rez <arg> Resource files (deprecated)
The terminal process "java '-Xms768m', '-Dfile.encoding=UTF-8', '-Dapple.awt.UIElement=true', '-jar', '/Users/rda/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.0.1-2021-04-21-1bb58d97e/bin/monkeybrains.jar', '-o', 'bin/TrainingHR.prg', '-f', '/Users/rda/OneDrive/Home/GarminConnect/gitRepos/TrainingHR/monkey.jungle', '-y', '/Users/rda/OneDrive/Home/GarminConnect/developer_key', '-w', '-l', '3', '-d', 'edge530_sim'" terminated with exit code: 100.
