Acknowledged
SDK Manager on Linux crashes when downloading SDKs and they fail when compiling an app.
I am running an arch linux system and have downloaded the SDK manager.
The manager starts fine but when I download an SDK it crashes with the error message:
Segmentation fault (core dumped)
When I open the manager again it says the SDK is installed and I can set it as my current SDK, but when I try to compile an app with it, it throws up a bunch of errors that weren't coming up before such as:
Cannot resolve type 'Boolean'
This happens for any SDK newer than 4.0
If I download SDK version 4.0.2 it still gives the seg fault but the SDK works to compile an app.
Parents
  • I noticed that and I did add
    import Toybox.Lang;
    but then it would start giving me errors about a bunch of other things that had worked before, which is why I assumed it was maybe because the manager hadn't downloaded the full SDK or something like that.
    But all of a sudden, I tried it again just now and everything compiles fine and runs when I copy it to my Garmin watch. However now the emulators have stopped working!!!
    I get the error:
    Unable to connect to simulator.
    I've seen lots of other people have had issues like this, but this is a first for me. The emulators have always worked right from the start. I tried removing everything Garmin related on my PC and tried installing from scratch to try and fix the previous issue, but now I can't get any emulators to run.
Comment
    import Toybox.Lang;
    I get the error:
Children
No Data
