Acknowledged
SDK bug in loading properties
Hello,
I have a boolean-property which stopped working, i.e. its value upon invoking
Toybox.Application.Properties.getValue("somePropertyKey")
is 'true' regardless of whether it is set to true/false in properties.xml;
Since it used to work I have changed SDK and found out it worked properly with older SDKs,
i.e. leaving code+properties intact (w/ the prop set to 'false'),
and only changing the SDK being used to compile/run, then compiling+running yield the following results:
  • connectiq-sdk-mac-4.1.1-2022-03-14-18db583bc: Properties.getValue return false, i.e. as expected
  • connectiq-sdk-mac-4.1.2-2022-04-07-15e8df3ed: Properties.getValue return false, i.e. as expected
  • connectiq-sdk-mac-4.1.3-2022-05-10-b3aaee541: Properties.getValue return TRUE instead of false
  • connectiq-sdk-mac-4.1.4-2022-06-07-f86da2dee: Properties.getValue return TRUE instead of false
  • connectiq-sdk-mac-4.1.5-2022-08-03-6e17bf167: Properties.getValue return TRUE instead of false
  • connectiq-sdk-mac-4.2.0.beta1-2022-10-11-bff57b73c: 'make' fails w/ 'Error 100' and does not provide any further details
Unless I am missing something, this is a bug, which might also be related to:
- https://forums.garmin.com/developer/connect-iq/i/bug-reports/bug-boolean-properties-with-default-value-true-can-t-be-changed-in-simulator
- https://forums.garmin.com/developer/connect-iq/i/bug-reports/sdk-4-1-1-settings-issues
Parents Comment Children
No Data
