Acknowledged
SDK bug: ANT LightNet data not resetting when LightNet device is disconnected (last values remaining visible)
I'm using
- ANT LightNet Taillight mode
- ANT LightNet Battery
values in order to display the VARIA RTL 516 status in a datafield. The status is displayed correctly when RTL 516 device is (initially) off and then switched on. After switching the RTL 516 device off, the last values keep visible (battery level and light mode on).
There should be a reset of these values by the SDK after ANT connection timeout.
Parents
  • I agree that things could be implemented badly. But the requirements are nearly the same like with an ANT heartrate, speed, cadence or power meter (I'm in road bikes). If there is no initial or a lost connection, values are resetted quickly there.
Comment
Children
No Data
