Acknowledged
CIQQA-3301
SDK 8.2.0 - No local documentation for Linux
Package "connectiq-sdk-lin-8.2.0-2025-05-27-67ddf1dcb" does not contain local HTML documentation.
"README.html" redirects to "./doc/docs/Readme/Getting_Started.html", but there is no directory "./doc/docs".
  • The release notes for 8.1.1 are missing in 8.2.1 docs.
  • This appears to be fixed in 8.2.1, at least for Linux.
  • Probably related to this:
    Documentation Changes
    New Features
    • Change documentation format delivered with the SDK.
  • On Windows it is included. I just pulled out an old laptop and downloaded the SDK on there just for this.
    These are the release notes:
    Release Notes
    v8.2.0
    API Changes
    New Features
    • Add an option to include timestamps for accelerometer and gyroscope data samples in Sensor.SensorData.
    • Newer devices will require SDK 7.4.3 or greater in order to sideload an app. SDK 7.4.3 or newer will build sideloadable apps for all devices.
    Simulator Changes
    Bug Fixes
    • Match device behavior when a menu theme is selected that is not available.
    • Fix large pressure values being returned by the API.
    • Fix incorrect string showing for Toasts.
    • Add transparency to the default music player icons.
    • Fix custom menu drawing issues when dragging on touch devices.
    • Disable the Save FIT Data button in Data Fields > Activity Dialog until an activity has been saved.
    • Fix menus not wrapping to the bottom when the up key was pressed.
    • Fix issues with some OAuth flows.
    • Fix widget app types not launching in glance mode.
    • Fix incorrect start button behavior on Vivoactive 6 when the action menu is visible.
    • Fix incorrect accel sensor data being returned via the API.
    Compiler Changes
    New Features
    • Move constant folding of has checks with API functions to the -p optimization level.
    Bug Fixes
    • Fix incorrect permission error when a poly type contains a type that requires a permission that is not enabled.
    • Fix compilation failure when a typedef with a callback references itself.
    • Fix project export not erroring when the selected SDK does not support the downloaded device configurations.
    • Fix type casting using ? being treated as a ternary expression.
    • Fix compiler errors when XML files contained UTF-8 BOM encoding.
    • Fix circular dependency error not being caught with self.
    • Fix circular dependency error not being caught during super class static initialization.
    • Fix critical compiler error when path contains special symbols.
    • Fix type check error when static member expressions reference another static member.
    • Fix self not referencing the subclass when used in the parent class.
    • Fix incorrect array index out of bounds error when a poly type contains multiple tuples of different sizes.
    • Fix incorrect type check error when using the new operator with a poly type.
    • Fix type checking bug on enum value comparisons.
    • Fix a bug in the branch elimination optimization, which caused invalid processing of ternary expressions.
    Language Server Changes
    New Features
    • Add support for call hierarchy.
    Bug Fixes
    • Fix signature help not showing in certain cases.
    • Fix real-time error checking showing errors that are not seen in a full build for device.
    • Reduce memory usage of the language server.
    New Features
    • Add section for the new Notifications module.
    Bug Fixes
    • Various updates to documentation.
  • Same on mac, impossible to know what's added/fixed in this release
