Because of the quirkiness of the null checking with the Monkey C compiler, there are instances where I need to help the compiler. In the example below, the compiler thinks that the variable _posInfo is a polytype of either an Position.Info or Null. To clarify that it is indeed not null, I specify the type as Position.Info.
var altitude = (_posInfo as Position.Info).altitude;
However, when I do this, I get the following error:
fenix7: 'Info' is ambiguious and exists in multiple imported modules [$.Toybox.Position.Info, $.Toybox.Sensor.Info, $.Toybox.Activity.Info].
I have imported the three modules mentioned, but compiler seems to be ignoring the fact that I qualified the Info object as "Position.Info". Even if I completely qualify it as "$.Toybox.Position.Info" the error persists.
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
