Ticket Created
SDK 8.0.0 BETA and language server build process
I tried using the SDK 8.0.0 BETA today and was able to get one smaller, more simple project working -- so I know the SDK works on my MacOS setup. However, I also ran into some issues, which seem to be specific to the language server build process (or whatever the process should be called):
1. One of my projects is able to get to 100% on the language server build processand displays warnings; however, when I attempt to run the app on the simulator, the process simply hangs. Sometimes it builds the PRG and sometimes it hangs prior. In both cases, the PRG never makes it to the simulator (whether it's already running or not). There's also no way to recover the build process and/or stop it; the little blue line continues to move at the top of the "Run and Debug" tab. The only way to stop this is to close the workspace/window. Whatever is going on also seems to cause an issue with "Find in Files", showing a subtext as "A system error occurred (spawn EBADF)".
2. Another project hangs around 33% during the language server build process, then seems to timeout and displays an error as such:
approachs7042mm: Error occurred while reading Monkey C file: Cannot invoke "String.split(String)" because the return value of "java.util.Properties.getProperty(String)" is null
In both the above cases, the projects compile and run just fine under SDK 7.4.3 and the older Monkey C plugin.
  • , what is the command line parameters being used for the build? The full output of the build command from the TERMINAL tab would be great to see. Would you be willing to share your project, or a small project that has this issue with us? If so, could you email it to [email protected]?
  • I don't really understand what is "language server build process". But from your comment it looks like the VSC extension is the problem and not the compiler. Did I get that right? What happens when you run the compilation in command line? Does it also fail in the middle of some builds? Or does that produce a prg file in 100$ of the cases?
  • Further this report, I tried a couple other things:
    - I downgraded to the older version of the Monkey C plugin (version 1.0.11) and the compiler in SDK 8.0.0 BETA works as expected.
    - I kept the new version of the Monkey C plugin (version 1.1.0) and downgraded the SDK to 7.4.3 and experienced a similar crash/hang when trying to run the app.
    I also thought this might be related to the fact that I typically have two or three active Connect IQ apps open in Visual Studio Code, but even with only a single project open the problems remain.
