Ticket Created
SDK 8.0.0 BETA and language server build process
I tried using the SDK 8.0.0 BETA today and was able to get one smaller, more simple project working -- so I know the SDK works on my MacOS setup. However, I also ran into some issues, which seem to be specific to the language server build process (or whatever the process should be called):
1. One of my projects is able to get to 100% on the language server build processand displays warnings; however, when I attempt to run the app on the simulator, the process simply hangs. Sometimes it builds the PRG and sometimes it hangs prior. In both cases, the PRG never makes it to the simulator (whether it's already running or not). There's also no way to recover the build process and/or stop it; the little blue line continues to move at the top of the "Run and Debug" tab. The only way to stop this is to close the workspace/window. Whatever is going on also seems to cause an issue with "Find in Files", showing a subtext as "A system error occurred (spawn EBADF)".
2. Another project hangs around 33% during the language server build process, then seems to timeout and displays an error as such:
approachs7042mm: Error occurred while reading Monkey C file: Cannot invoke "String.split(String)" because the return value of "java.util.Properties.getProperty(String)" is null
In both the above cases, the projects compile and run just fine under SDK 7.4.3 and the older Monkey C plugin.
Parents
  • Further this report, I tried a couple other things:
    - I downgraded to the older version of the Monkey C plugin (version 1.0.11) and the compiler in SDK 8.0.0 BETA works as expected.
    - I kept the new version of the Monkey C plugin (version 1.1.0) and downgraded the SDK to 7.4.3 and experienced a similar crash/hang when trying to run the app.
    I also thought this might be related to the fact that I typically have two or three active Connect IQ apps open in Visual Studio Code, but even with only a single project open the problems remain.
Comment
Children
  • The two projects I have issues with are both really big projects; one has 71 Monkey C source files and the other has 90. Neither has any custom command-line arguments in the plugin settings or the jungle file. Could this be related to the size of the project?
    Is there a way for me to manually run the language server command on my one project that hangs at 30% and displays the String.split error?
    For both projects, when I try to run the app the terminal tab displays only this, with no actual command: "Executing task: monkeyc: Building For Device"
    I did manage to somehow get something to pop up in an error dialog box this morning on one of the projects, and it allowed me to see the following details:
    2025-01-10 09:07:45.466 [info] [Error - 9:07:45 AM] JSON Language Server client: couldn't create connection to server.
    2025-01-10 09:07:45.466 [info] Error: spawn EBADF
    at ChildProcess.spawn (node:internal/child_process:420:11)
    at spawn (node:child_process:796:9)
    at fork (node:child_process:173:10)
    at e.fork (node:electron/js2c/node_init:2:18231)
    at /Applications/Visual Studio Code.app/Contents/Resources/app/extensions/json-language-features/client/dist/node/jsonClientMain.js:1:498227
    at new Promise (<anonymous>)
    at /Applications/Visual Studio Code.app/Contents/Resources/app/extensions/json-language-features/client/dist/node/jsonClientMain.js:1:497802
    at async D.createConnection (/Applications/Visual Studio Code.app/Contents/Resources/app/extensions/json-language-features/client/dist/node/jsonClientMain.js:1:297142)
    at async D.start (/Applications/Visual Studio Code.app/Contents/Resources/app/extensions/json-language-features/client/dist/node/jsonClientMain.js:1:287364)
    at async _ (/Applications/Visual Studio Code.app/Contents/Resources/app/extensions/json-language-features/client/dist/node/jsonClientMain.js:1:561152)
    at async t.startClient (/Applications/Visual Studio Code.app/Contents/Resources/app/extensions/json-language-features/client/dist/node/jsonClientMain.js:1:555412)
    at async t.activate (/Applications/Visual Studio Code.app/Contents/Resources/app/extensions/json-language-features/client/dist/node/jsonClientMain.js:1:576296)
    at async K0.n (file:///Applications/Visual%20Studio%20Code.app/Contents/Resources/app/out/vs/workbench/api/node/extensionHostProcess.js:115:4447)
    at async K0.m (file:///Applications/Visual%20Studio%20Code.app/Contents/Resources/app/out/vs/workbench/api/node/extensionHostProcess.js:115:4410)
    at async K0.l (file:///Applications/Visual%20Studio%20Code.app/Contents/Resources/app/out/vs/workbench/api/node/extensionHostProcess.js:115:3866)
  • , what is the command line parameters being used for the build? The full output of the build command from the TERMINAL tab would be great to see. Would you be willing to share your project, or a small project that has this issue with us? If so, could you email it to [email protected]?
