function getIteratorBodyBattery() {
// Check device for SensorHistory compatibility
if ((Toybox has :SensorHistory) && (Toybox.SensorHistory has :getBodyBatteryHistory)) {
return Toybox.SensorHistory.getBodyBatteryHistory({});
return null;
var intBB = 0;
var sensorIterBodyBattery = getIteratorBodyBattery();
if (sensorIterBodyBattery != null) {
intBB = sensorIterBodyBattery.next().data / 100;
Line 12:
stops with error in SDK 7.3.0:
Details: Failed invoking <symbol>
There is no probnlem with that in SDK 7.2.1:
SDK 7.2.1 sensorIterBodyBattery: ---------------------- mMax = 37 (Lang.Number) mMin = 35 (Lang.Number) mNewestSampleTime = Lang.Object mOldestSampleTime = Lang.Object
Values with SDK 7.3.0:
SDK 7.3.0 sensorIterBodyBattery: ---------------------- mMax = 0 (Lang.Number) mMin = 127 (Lang.Number) mNewestSampleTime = Lang.Object mDateTime = 0 (Lang.Number) mOldestSampleTime = Lang.Object mDateTime = 0 (Lang.Number)
The minimum-value is 127 (body battery cannot be greater than 100) and die maximum value is 0 (max is smaller than min).
The setup of the simulator is identically.
IMHO there is bug in
Is there an idea to fix that?
Greetings,
Ronny
1076493
in reply to Brandon.ConnectIQ
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
1076493
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
