Acknowledged
SDK 6.3.0 simulator crashing frequently
SDK 6.3.0 simulator now crashes with nearly every other menu operation it seems. This is happening with the Fenix 7X, I'm not seeing this with the FR 235. Open profiler may work, may crash. Open memory usage may work, may crash. Set low power mode may work, may crash. I didn't have this problem with prior versions. This is on Win 10 with VS 1.81.1. There are no error messages I can see to report.
  • I've found out by trial and error that it happens when I use the -k compiler option so the profiler starts with the simulator, and as long as the profiler window stays open everything works OK. Close the profiler window, then the next menu item selection in the simulator will crash it. Without -k, opening and closing the profiler window doesn't cause a problem.
  • I updated to 6.3.1 and the latest Java version, but still I cannot set low power mode without it the simulator just going away and no error message. SDK 6.2.2 used to work but now it doesn't. No response from Garmin so I don't expect to ever get fixed on purpose, maybe I'll get lucky and they'll fix it by accident in some future version.
