Acknowledged
SDK 6.2.2 compiler optimization degradation compared to SDK4.2.x
When switching to SDK 6.2.2, compiler optimization -O 3p generates code that is significantly less optimized for speed/number of instructions than with the same optimization with SDK 4.2.x.
I have a widget that used to run fine when compiled with SDK 4.2.x, but under SDK 6.2.2 I now get "code executed too long" error without any code change (I was able to optimize my code manually to get back under the limit but it begs the question on what was changed for compiler optimization in the new sdk)
This case is on fenix 7.
Maybe this can be useful to know for other developers since one should make sure to test corner cases when close to the limit with the older sdk.
Parents Comment Children
No Data
