Both fenix 6 and fenix 6 pro now break in the simulator (worked fine in 4.1.7).
fenix 6 breaks with an out-of-memory error when pressing Enter key on the glance view. I added breakpoints to the widget entry points, but the widget is never loaded, it runs out of memory in garmin's CIQ code.
fenix 6 pro runs out of memory from the start and never enters the code (using the debugger).
Error: System Error Details: Failed loading application Encountered app crash.
Works fine on e.g. venu, fenix 7, fr 965, etc.
Also fenix 6 pro runs fine if I disable the glance view in the simulator.
I would prefer to not have to rollback the SDK version since it would lose support for the newer devices.
I have a fenix 6 pro device and the widget runs fine on it (with glances enabled), on the other end I received several reports of users with fenix 6 (non pro) that now cannot open the widget.
I can follow-up with more info, just contact me.
André Zunido
over 2 years ago
in reply to flocsy🤠
Cancel
Up
0
Down
More
Cancel
Comment-
André Zunido
over 2 years ago
in reply to flocsy🤠
Cancel
Up
0
Down
More
Cancel
Children
