Given:
module Statics {
var ok as Boolean = false;
class C {
function initialize() {
C.foo();
static function bar() as Void {
C.foo();
private static function foo() as Void {
ok = true;
(:test)
function static_from_initialize(logger as Logger) as Boolean {
ok = false;
var c = new C();
return ok;
(:test)
function static_from_static(logger as Logger) as Boolean {
ok = false;
C.bar();
return ok;
The code compiles and works as expected with sdk-4.1.5 and earlier (ie C.foo() is successfully called, both from C.initialize() and from C.bar()),
With sdk-4.1.6 the type checker is happy (it compiles with Strict type checking), but fails at runtime with:
Executing test Statics.static_from_initialize... Error: Symbol Not Found Error Details: Could not find symbol 'foo' Stack: - initialize() at /Users/mwilliams/www/git/monkeyc-optimizer/test/OptimizerTests/source/OptimizerTestsLookup.mc:288 0x10003151 - static_from_initialize() at /Users/mwilliams/www/git/monkeyc-optimizer/test/OptimizerTests/source/OptimizerTestsLookup.mc:302 0x10003181 - evaluate_test_entries_30_to_39() at UnitTests.mc:182 0x10001bc6 - runTest() at UnitTests.mc:215 0x10001d92 ERROR ------------------------------------------------------------------------------ Executing test Statics.static_from_static... Error: Symbol Not Found Error Details: Could not find symbol 'foo' Stack: - bar() at /Users/mwilliams/www/git/monkeyc-optimizer/test/OptimizerTests/source/OptimizerTestsLookup.mc:291 0x1000312f - static_from_static() at /Users/mwilliams/www/git/monkeyc-optimizer/test/OptimizerTests/source/OptimizerTestsLookup.mc:308 0x100031b2 - evaluate_test_entries_30_to_39() at UnitTests.mc:185 0x10001bed - runTest() at UnitTests.mc:215 0x10001d92 ERROR
I caught this building the Meditate folder in the open source project https://github.com/vtrifonov-esfiddle/Meditate . The built project runs correctly with 4.1.5 and earlier, but fails when you hit the start button with 4.1.6.
It also looks like the 4.2.0-beta sdk has the same issue - and in fact it seems to be another compiler2 vs compiler1 issue, because compiling with 4.1.6 or 4.2.0-beta at -O0 fixes the problem.
EDIT:
The bug only affects private and protected references. And if I look at the output with -g, I see this with from sdk-4.1.5:
lgetv 0
spush C
getv
spush <globals/Statics/C/<>foo>
getv
frpush
invokem 1
popv
But this from sdk-4.1.6
lgetv 0
spush C
getv
spush foo
getv
frpush
invokem 1
popv
So 4.1.5 is correctly pushing the "private" symbol for foo, while 4.1.6 is incorrectly pushing the public symbol.
Also, if I make foo protected, instead of private, and create a class D which extends C, and have that try to call C.foo, it fails the same way with 4.1.6 AND 4.1.5 (but again, the type checker is happy with both compiler versions).
markw65
in reply to Travis.ConnectIQ
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
markw65
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
