Ticket Created
CIQQA-1038
SDK 4.1.1 Settings issues
If I have a boolean property, with a default value of true, then I can't change it in the simulator's App Settings Editor. The exact same code worked fine in 4.0.10, and it *looks* like it works in 4.1.1, but the property gets stays "true" no matter what I do.
If I change the default to false, then it toggles correctly. If I leave it set to false in the editor, change the default to true, and re-run the app, it stays false until I toggle it back to true, at which point it sticks to true again.
Parents
  • I have the same issue in 4.1.4 and 4.1.5.  The boolean property worked until I added more settings in settings.xml.  Then, all old and new boolean properties did not work.  I had to change them all to a list with Yes/No (0/1) as pick options to overcome this issue.  Size issue with settings.xml?
Comment
Children
No Data
