Ticket Created
CIQQA-1040
SDK 4.1.1. menu interactivity results in anonymous error
As per forum thread: Is there a bug with latest SDK simulator and menus? - Discussion - Connect IQ - Garmin Forums
STEPS TO REPLICATE:
1. Compile an app with a Toybox.WatchUi.Menu for Venu 2s using the latest SDK (4.1.1).
2. Open the menu eg: something like:
   function onMenu() {
	  WatchUi.pushView(new Rez.Menus.MainMenu(), new ACHMenuDelegate(), WatchUi.SLIDE_DOWN);
	  return true;
3. Try to select the second item in the menu by touching the screen and swiping...
EXPECTED RESULTS:
The second menu item should come into focus...
ACTUAL RESULTS:
An anonymous error as per the below...
Error: Symbol Not Found Error
Details: Failed invoking <symbol>
Stack:
ADDITIONAL
If I use the keyboard (up / down arrows etc) to move the menu, I can use all menu items by clicking on the screen without any error.
I can also access the menu item by simply tapping on it.
It is only when I swipe that I see the anonymous error, but I always see the anonymous error if I swipe.
