In 10-50 seconds, a screen turns black in FR45 or Vivoactive 4 when it it is not redrawn every single on-update. Simply no-operation in onUpdate will turn the screen black instead of keeping the last image.
No problems reported on other devices.
Reason for not redrawing the screen all the time: I strive for battery saving and don't render seconds. It takes a lot (time-wise) to compute all charts and redraw the screen every time. So I redraw it only once a minute and I had a magnificent battery life. Better than stock watch faces.
How to fix(?):
- can the problem be solved by updating the firmware of the affected watches?
- is there a way how to tell the watch just to keep the current display
How to measure a battery impact(?):
- how to measure the battery impact empirically? I just measured a rendering time in ms, but don't know what impact on the battery it actually has. Is there a better way to measure and optimize the battery impact?
- what operations actually drains the battery?
- Does BufferedBitmap count to the watch face memory limit? If not, can prerendering into it can improve a battery consumption?
Thanks for your guidance and fixing the affected devices firmware.
