Complete
Documentation updated and waiting for future release.
Runtime error with Moment.subtract() when subtracting a Duration
Hi
The following Simple Data Field code snippet fails on my Vivoactive HR. It works in the simulator.
using Toybox.WatchUi;
using Toybox.Time;
using Toybox.Time.Gregorian;
    function compute(info) {
		var aDuration = Gregorian.duration({:minutes => 10});
		var aMoment = Time.now();
		var anEarlierMoment = aMoment.subtract(aDuration);
        return 0.0;
The error log (CIQ_LOG.TXT) says:
ERROR: System Error
DETAILS: Expected a Moment object
STORE_ID: 00000000000000000000000000000000
CALLSTACK:
@PC = 0x300013fe
F:\Eclipse2\workspace\ATest\source\ATestView.mc (compute:14)
where compute:14 is the line containing "var anEarlierMoment..."
The Connect IQ SDK documentation for Module: Toybox::Time says
Moment.subtract() can be used to subtract a Duration from a Moment to give "An earlier Moment"
and specifically in the Instance Methods Summary for Class: Toybox::Time::Moment it says
subtract(subtrahend) ⇒ Toybox::Time::Duration, Toybox::Time::Moment
Subtract a Duration or Moment from a Moment.
so I expected it to work.
Parents
    Former Member in reply to Travis.ConnectIQ
    Thanks for your reply.
    In fact subtracting values is the workaround I've been using. I just wanted to flag up the issue.
    It's a shame the documentation is wrong (it says Subtract a Duration or Moment from a Moment  - Since: 1.0.0)
    It's also a shame the simulator and real device behave differently - I only saw the problem because it fails on the watch I happen to have.
Comment
Children
