Ticket Created
WERETECH-12843
RFC: Allow to run tests verbose or not
Currently we can run the testsuite like so and we get a whole lot of output:
monkeydo ./bin/xxxx.test.prg devicename -t
Executing test TestModule.testName
PASS
[snip, rinse repeat for every test]
RESULTS
Test: Status:
TestModule.testName PASS
Ran x test
With smaller apps this is fine, but when the things become bigger, your screen gets filled with data.
My proposal is to add a -v to the command. With -v you get the output as described above. Without it you only get the following output:
RESULTS
Test: Status:
TestModule PASS
OtherTestModule PASS
Ran x tests
# When a failure occurs:
OtherTestModule.subtest FAILED
This would make it much easier to process big chunks of data.
