Complete
over 2 years ago
The GCM team was unable to reproduce this issue.
If there is any more information that can be provided to assist the team, I will re-open the Report.
Regression: Garmin Connect version 4.49+ for Android is unable to save app settings on phones with Android 8
After updating from Garmin Connect version 4.48 (Android) to 4.49 or any higher version, I am not able to change app settings for any CIQ application that I have installed on my Edge 1000. After opening the Settings page for a CIQ application, modifying a setting value and tapping on "DONE" button, nothing happens. I tried to remove all CIQ applications from Edge and install a random one, but it still doesn't work.
How to reproduce:
1. Install Garmin Connect for Android version 4.49 or greater on a phone with Android 8.0 Oreo
2. Pair a Garmin device
3. Install a random CIQ application (e.g. I tried with "Gears 2")
4. Try to change a setting and tap on "DONE" button
5. After tapping on "DONE" button nothing happens (it should save the settings and close the page)
The only workaround that I was able to find, is to downgrade to version Garmin Connect 4.48.
Parents
  • Hi Racheal,
    The same issue is still present on the latest Android version 4.54. I tried multiple versions between 4.49 and 4.54 and all of them have the same issue. Based on my testing, I think that a regression was introduced with version 4.49.
Comment
  • Hi Racheal,
Children
No Data
