I got the following exception when trying to build my app:
Exception in thread "main" java.lang.StackOverflowError
at java.base/java.util.LinkedHashMap$LinkedKeyIterator.<init>(LinkedHashMap.java:1046)
at java.base/java.util.LinkedHashMap$LinkedKeySet.iterator(LinkedHashMap.java:701)
at java.base/java.util.HashSet.iterator(HashSet.java:183)
at java.base/java.lang.String.join(String.java:3666)
at com.garmin.monkeybrains.compiler2.ir.types.PolyType.toString(PolyType.java:383)
at com.garmin.monkeybrains.compiler2.ir.types.InterfaceType.toString(InterfaceType.java:328)
at com.garmin.monkeybrains.compiler2.ir.types.PolyType.toString(PolyType.java:378)
Because the compiler crashed, it couldn't tell me what line number the error came from. After some guesswork, I figured out the error was caused by an interface that references its own type in a method signature, i.e.:
typedef Foo as interface {
function bar(otherFoo as Foo) as Boolean;
Changing the type of otherFoo to object prevents the compiler from crashing.
Unfortunately, I haven't been able to produce a self-contained bit of code that replicates the bug for sharing.
The error happens only for SDK versions 7.1.0+.
