Ticket Created
WERETECH-11737
red circle drawn around 390x390 round devices in the simulator
Hey, I am working a few days around my new watch face design and there's a problem I've encountered only in the Venu and the Venu Mercedes-Benz edition, I've used
dc.setColor(Graphics.COLOR_BLACK, Graphics.COLOR_TRANSPARENT);
        dc.drawCircle(dc.getWidth()/2, dc.getHeight()/2, dc.getWidth()/1.8);
        dc.fillCircle(dc.getWidth()/2, dc.getHeight()/2, dc.getWidth()/1.8);
to get a black background (the reason for the /1.8 was because I had the problem with other devices but using '/1.8' instead of '/2' solved it). In those devices I get a red circle around the device's screen: https://ibb.co/4ZZcnqT (kinda hard to see but I afraid that if the problem is not with the simulator, then it will be really clear in real life and I will get bad reviews for this). Did anyone else encountered the same problem, anyone knows how to solve it?
Also if anyone has a Venu or Venu Mercedes-Benz edition and can check for me if this problem occurs in real life device and not only in the simulator It will be really appreciated. Here's the link to the prg file - https://filebin.net/pfnfwpy1kkqi5nab .
TY in advance for anyone that will try to help! It is the very last thing I need to fix before uploading it to the connect iq shop!
Parents
  • I tried changing your code to get rid of drawCircle(), and yep, the weird circle is still there:
        function onUpdate(dc as Dc) as Void {
            dc.setColor(Graphics.COLOR_BLACK, Graphics.COLOR_BLACK);
            dc.clear();
    		dc.setPenWidth(1);
            var clockTime = System.getClockTime();
    I modded the Analog SDK sample so it runs for Venu, and I see the same problem (in the sim). To make it clearer, I changed the code so it just displays a black background (although I see the problem either way)
        public function onUpdate(dc as Dc) as Void {
            dc.clear();
            return;
    /resized-image/__size/320x240/__key/commentfiles/fb5d84b10a5745448a7a45dafc1faa43-6e81f76c-4019-4ee1-9f89-903b0c272bdb/pastedimage1633390943753v1.png I think this makes it pretty clear that this is likely a simulator issue -- if you have a chance, you could file a bug report.
Comment
            dc.clear();
    		dc.setPenWidth(1);
            dc.clear();
            return;
Children
No Data
