Hi,
Seeing some odd behaviour with Time calculations not returning Number, as per the documentation. https://developer.garmin.com/connect-iq/api-docs/Toybox/Time/Moment.html#compare-instance_function
This then triggers an unrecoverable error if the output is used within a subsequent Time calculation:
ERROR: Unhandled Exception DETAILS: NONE STORE_ID: CALLSTACK: UnexpectedTypeException: Expected an object of type Time.Duration native function
It looks like the ultimate cause might be a problem with Time.Moment.add();
For example:
function momentNType(moment) {
var n = moment.value();
System.println(moment+" has value of "+n);
nType(n);
function nType(n) {
System.println(n+" is Number? "+(n instanceof Number)+" Long? "+(n instanceof Long));
function getOClock(nHoursAgo) {
var nowTime = Time.now();
var info = Gregorian.info(nowTime,Time.FORMAT_SHORT);
var adjustSeconds = (nHoursAgo-1)*3600 + info.min*60 + info.sec;
System.println("CALCULATE OCLOCK WITH "+nHoursAgo);
nType(adjustSeconds);
// Subtracting a Duration from a Moment was not supported until ConnectIQ 3.0.0.
// If backward compatibility is a concern, it may be best to add a negative Duration instead.
return nowTime.add(new Time.Duration(-adjustSeconds));
// And then...
var heartTime = getOClock(heartGraphInSeconds/3600); // Time.Moment
var difference = Time.now().compare(heartTime);
System.println("Output from getOClock method");
momentNType(heartTime);
System.println("GETS");
nType(difference);
// CONSOLE OUTPUT
Obj: 192 has value of 1599465600
1599465600 is Number? false Long? true
GETS
3928 is Number? false Long? true
G
9635560
in reply to Travis.ConnectIQ
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
9635560
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
