I am having some trouble converting hex numbers to integers. I can't seem to make the string.toLongWithBase(base) function work ?
The first test case should be the maximum 32 bit signed integer, the second test case returns null since it is too big.
I have not idea why the third test case generates an exception as it cannot find the string function toLongWithBase ?
Any ideas ??
Thanks
sNum = "7fffffff";
dNum = sNum.toNumberWithBase(16);
Sys.println("str : " + sNum + " num: " + dNum); // output = str : 7fffffff num: 2147483647
sNum = "ffffffff";
Sys.println("str 1 : " + sNum + " num: " + dNum); // output = str 1 : ffffffff num: null
sNum = "ffffffff";
dNum = sNum.toLongWithBase(16); // output = Error: Symbol Not Found Error Details: Could not find symbol 'toLongWithBase'
Sys.println("str 2 : " + sNum + " num: " + dNum);
