Acknowledged
Problem reading the manifest file
Hi.
It seems that since a couple of hours, i m not able to edit manifest file under Eclipse.
I have noted "htttp://www.garmin.com/xml/connectiq" is no more accessible.
As the manifest file can't be read, i m no more able to use simulator or IQ plugin on Eclipse.
Is someone having the same issue?
Regards.
    Former Member in reply to Bastos65
    I had the same problem, and reinstalling eclipse and the ConnectIQ plugin fixed it. (I was using eclipse 2020-06 and upgraded to 2020-09.)
  • Hi,
    I fixed issue, it seems last sdk update for éclipse plug-in was not correctly installed. Then i was not able to open manifest file with error message « Error opening manifest.xml » in eclipse console.
    I removed plugin connect IQ and SDK and reinstalled  both. All ok now.
    By the way you are right about : htttp://www.garmin.com/xml/connectiq
    No mater if the address is valid or not.
    Regards.
  • > I have noted "htttp://www.garmin.com/xml/connectiq" is no more accessible.
    In XML the namespace URI is not necessarily a valid URL, it is just a namespace name. It is used to disambiguate potentially conflicting names.
    What happens when you try to open the manifest? Do you get an error, an empty window, ...
    I do know that you can run into some weird issues if the manifest references a device that you have not downloaded using the SDK manager. Might this be the source of your problems?
    Hello. Are you getting a specific error when trying to open the manifest file in Eclipse?
