Example:
class Broken {
private static const FOO = 42;
public static function getFoo() as Number {
return Broken.FOO; // <-- crashes here
(:test)
function testBroken(logger as Logger) as Boolean {
logger.debug(Broken.getFoo());
return true;
Prior to sdk-6.2.0, this works as expected (except in 4.1.6, which had a similar, but not identical bug). In sdk-6.2.0 at -O0, it also works.
But at -O1 and above, it crashes on line 4. As far as I can tell, the optimizer has removed the definition of FOO from class Broken, but is still referencing it from getFoo().
Looking at the -g output, in 4.1.7 through 4.2.4, the body of getFoo is optimized to:
argc 1
ipush 42
return
in other words "return 42;". In 6.2.0 its not optimized at all:
argc 1
lgetv 0
spush Broken
getv
spush <globals/Broken/<statics>/<>FOO>
getv
return
In both cases, FOO has been removed from the globals/Broken/<statics> CLASSDEF.
So it seems that 6.2.0 introduced a disconnect between the code that removes unused constant definitions, and the code that is supposed to optimize away their uses.
