After upgrade the SDK to 6.2.0/6.2.1, I found that the println doesn't work on console. I tried it on windows and linux console, neither works.
I just built a vscode project and it works. But I think the console should have worked.
This is the console log, I've update it on the discussion area, but I think I should paste it here for official report. Thanks.
When I execute the command:
monkeydo .\test.prg fr255
it seems that there is error as following and those cause the disconnect from the simulator. That's the reason I cannot print the output of "println". Iruned it on windows powshell.
Exception in thread "Thread-0" java.lang.IllegalArgumentException: Invalid UUID string: 1C
at java.base/java.util.UUID.fromString1(UUID.java:280)
at java.base/java.util.UUID.fromString(UUID.java:258)
at com.garmin.connectiq.common.communication.channels.device.DeviceChannel.getUuid(DeviceChannel.java:151)
at com.garmin.connectiq.common.communication.channels.device.DeviceChannel.messageReceived(DeviceChannel.java:198)
at com.garmin.connectiq.common.communication.channels.shell.ShellChannelManager$1.sendNotifiction(ShellChannelManager.java:217)
at com.garmin.connectiq.common.communication.channels.shell.ShellChannelManager.notifyChannel(ShellChannelManager.java:194)
at com.garmin.connectiq.common.communication.channels.shell.ShellChannelManager.messageReceived(ShellChannelManager.java:214)
at com.garmin.connectiq.common.communication.shell.ShellProcess$1.sendNotification(ShellProcess.java:368)
at com.garmin.connectiq.common.communication.shell.ShellProcess.notifyListeners(ShellProcess.java:355)
at com.garmin.connectiq.common.communication.shell.ShellProcess.notifyInputReceived(ShellProcess.java:366)
at com.garmin.connectiq.common.communication.shell.ShellProcess.access$100(ShellProcess.java:14)
at com.garmin.connectiq.common.communication.shell.ShellProcess$ReaderThread.run(ShellProcess.java:41)
yp
Cancel
Vote Up
-2
Vote Down
More
Cancel
Comment-
yp
Cancel
Vote Up
-2
Vote Down
More
Cancel
Children
