Acknowledged
Position.enableLocations documentation has a bug in code example (causes device to crash)
(See: https://forums.garmin.com/developer/connect-iq/f/discussion/319709/enable-location-bug-after-24-10-update)
The documentation at the following URL has a bug which causes a crash:
[https://developer.garmin.com/connect-iq/api-docs/Toybox/Position.html#enableLocationEvents-instance_function]
Original code:
if (Position has :CONFIGURATION_GPS_GLONASS_GALILEO_BEIDOU_L1_L5) {
    options[:configuration] = :CONFIGURATION_GPS_GLONASS_GALILEO_BEIDOU_L1_L5;
Correct code:
    options[:configuration] = Position.CONFIGURATION_GPS_GLONASS_GALILEO_BEIDOU_L1_L5;
Parents
  • For context, here's the full example:
    using Toybox.Position;
    var options = {
        :acquisitionType => Position.LOCATION_CONTINUOUS
    if (Position has :POSITIONING_MODE_AVIATION) {
        options[:mode] = Position.POSITIONING_MODE_AVIATION;
    } else if (Position has :CONSTELLATION_GPS_GLONASS) {
        options[:constellations] = [ Position.CONSTELLATION_GPS, Position.CONSTELLATION_GLONASS ];
    } else {
        options = Position.LOCATION_CONTINUOUS;
    // Continuous location updates using selected options
    Position.enableLocationEvents(options, method(:onPosition));
    function onPosition(info) {
        var myLocation = info.position.toDegrees();
Comment
    var options = {
    } else {
Children
No Data
