Acknowledged
Peak memory tracing crashes simulator
The peak memory usage feature in the simulator "Active Memory" cannot be enabled consistently. I've only managed to do it a few times. Clicking the checkbox does not enable the buttons except in rare circumstances, which I cannot reproduce except by luck. The few times I have been able to click the peak stack trace button, a dialog box appears and flashes for a little while, then the simulator crashes and just disappears. Has this "feature" ever worked, and if so, how to get it working properly?
Parents
  • I'm on win11 and sdk 7.2.1.  I haven't seen crashes, but here what I see.
    If I start and app. open "View memory", I see the current memory and peak (there is a peak when an app starts).  When I click on "enable peak memory detection", the buttons are grayed out.  But if I then do something that increases the peak, the buttons are no longer grayed and can be used.
    With some of my apps, I can easy trigger a new peak  by using File>Edit Persistent Storage>Edit Application.Properties data (app-settings) and then save it.
    I don't have an app that increases memory over time, but I'd suspect the buttons to be available once you get a new "peak memory" in that case.
Comment
Children
  • I can set breakpoints and get snapshots of memory usage but I could do that anyway with getsystemstats and println. Still, I get things like this:
    Hit breakpoint 1, onUpdate () at AnnulusWatch.mc:38
    Hit breakpoint 2, onUpdate () at AnnulusWatch.mc:39
    Hit breakpoint 3, onUpdate () at AnnulusWatch.mc:40
    Kill app for resume the app
    Failed to terminate app: Timeout
    Kill app for get stack backtrace
    [Ljava.lang.StackTraceElement;@19dad439
    And the peak stack trace never shows anything other than this:
    If peak memory usage is anything other than broken, I can't tell.
  • As a test, I used "Moneyc: New project", to create a simple WF without settings.  You can't get much simpler than this.
    Then to make it interesting, I commented out both onLayout and onUpdate.
    You still see the peak at startup.
    It's using 5.8K with a peak of 8.0k with an instinct2 in the sim.
    It's using 5.5k with a peak of 7.6k with a fr265.
    You really can't do anything in the code to reduce this.  Turning on
    project.optimization = 2
    did nothing
  • It's not leaks I'm worried about, I'm trying to optimize memory usage so I have more room to implement certain features. If I can find the actual peak maybe I can rewrite it and move on to chasing the next one until I get to one I can't fix.
  • I hacked one of my watch faces so that each time onUpdate is called, it uses more memory, and sure enough, after a bit, the buttons weren't grayed out.  Let it run a while longer, and the app ran out of memory.
    Like I said you'll see a peak when an app starts. (same watch face) I see about 2k difference.
    If the buttons stay grayed, that's good, as your peak isn't increasing - no leaks
  • That's not really helpful for me. If I do something to create a new fake peak to activate the buttons, I will no longer be able to detect the peak that I am actually looking for. It's a watch face, if it is increasing after it starts then it's leaking. I have a consistent 2-3k difference between used and peak depending on the device. Once it's peaked which is sometime before I can open the dialog it doesn't change after that. Based on some debug statements it's after "onLayout" so it's somewhere in one of the rabbit holes in onUpdate.
