Acknowledged
Occasional "Symbol Not Found Error" at any app startup for "venu2plus" on Ubuntu 22.04 with SDK 7.1.1
Steps to reproduce.
  1. Build "Menu2Sample" for "venu2plus" from SDK 7.1.1 samples (either with direct "monkeyc" invocation or with VS Code plugin).
  2. Run the script (see below).
  3. If app is started without crash, goto 2.
Script:
#/bin/bash
pkill -9 simulator || true
rm -rf /tmp/com.garmin.connectiq
rm -rf ~/.Garmin/ConnectIQ/simulator.ini
simulator &
sleep 1
monkeydo ~/.Garmin/ConnectIQ/Sdks/connectiq-sdk-lin-7.1.1-2024-04-17-66d0159ae/samples/Menu2Sample/bin/Menu2Sample.prg venu2plus &
Crash:
Error: Symbol Not Found Error
Details: 'Failed invoking <symbol>'
Time: 2024-06-05T15:19:19Z
Part-Number: 006-B3851-00
Firmware-Version: '19.05'
Language-Code: eng
ConnectIQ-Version: 5.0.0
Filename: MENU2SAMPLE
Appname: Menu2Test
Details: Failed invoking <symbol>
Stack:
Encountered an app crash.
This crash can also be seen for newly generated watch app project for "venu2plus". It occurs for fresh project and for "Menu2Sample" maybe in 10% of all times, but for my real project I see this almost every third run.
There can also be seen "Unable to connect to simulator" sometimes due to too short delay between "simulator" and "monkeydo" calls, but this is not the point of my concern.
This doesn't happen on SDK 6.4.2, and I haven't noticed such behavior for other devices I support both on 6.4.2 and on 7.1.1.
I tried to completely reinstall both devices and SDK by removing "~/.Garmin/ConnectIQ" directory.
I haven't tested my real app on physical device yet after migrating to 7.1.1, as it is not available at the moment. With 6.4.2 everything worked fine.
