Ticket Created
WERETECH-12014
Object-private vs Class-private
In the doc it says:
"The private modifier specifies that the member can only be accessed in its own CLASS"
1) https://developer.garmin.com/connect-iq/monkey-c/objects-and-memory/  -> "Data Hiding"
2) https://developer.garmin.com/connect-iq/reference-guides/monkey-c-reference/#datahiding
However, I'm unable to access private members in a static function of the same Class:
class A {
    private var _member;
    public function initialize(){
    public function calcMember(){
        _member = doSomeFancyCalculation();
    public static function createFromStorage() as A {
        var newA = new A();
        // Error: Symbol Not Found Error
        // Details: Could not find symbol '_member'
        newA._member = Storage.getValue("key_storedMember");
        return newA;
So unless this is something you wanna fix in the language to align with the docs and e.g. Java or C++, you should at least update the doc to correctly reflect the current behavior.
Without having tested it, I would assume that there's a similar issue with the protected-Keyword.
Corresponding forum thread with code sample:
https://forums.garmin.com/developer/connect-iq/f/discussion/279953/implementation-of-the-private-keyword#pifragment-702=2
SDK: connectiq-sdk-lin-4.0.6-2021-10-06-af9b9d6e2
Device: Simulator (fr945)
Parents Comment Children
No Data
