Acknowledged
Not all BLE Devices found by scanning
Having several BLE Sensors and wanting to display their data on-screen of the watch. Scanning for the BLE Sensor returns all kinds of apple devices, but not the sensor i'm looking for.
Both sensors contain Bluetooth Classic and Bluetooth Low Energy chips.
One of the older sensors still has a static LE mac address and shows up in the scan. NRF Connect shows this device as "Classic and LE Capable".
The newer sensors do not show up on the scan, and are shown in NRF Connect as "LE Only".
I have attempted to 'spoof' the newer sensor to appear as a device capable of both, but no luck.
If anyone could shed some light on this issue and perhaps a solution that would be great!
Parents
  • If you're talking BluetoothLowEnergy in Connect IQ, I have an app that will show you exactly what a garmin device can see:
    BleScan: https://apps.garmin.com/en-US/apps/9bcc8b66-8385-4afb-b93e-f69e01422284
    nRFConnect will show things you can't see with CIQ.
Comment
Children
  • That is pairing in the FW and not CIQ.
  • Thanks, I've seen your answer, good to know that you get the same result on your side! What I don't understand then, is that I am able to pair my regular heart rate monitor with my Fenix 5 over BLE... How can it be possible if the Fenix 5 doesn't support BLE ? Or maybe it is a specific BLE issue with this device model ?
  • The Fenix 5 doesn't support CIQ BLE.  The f5+ devices do. I have the f5 as a device that shows what happens with devices without BLE, but you are the first person to notice it.
  • I fully agree with you, randomization is a big issue if you want to connect such a device to your Garmin... I am not able to connect my device natively because it has randomization and I hoped that using Connect iQ could solve this issue but it seems it is not the case... I wanted to verify with Jim's app but it doesn't work on my Fenix 5... Did you tried Jim's app on your side ? I don't want to have to buy a Garmin Edge X30 head unit just for checking this point if it doesn't work afterwards...
  • With CIQ, things are not learned over a connection.  Services and characteristics must be defined in the app's BLE profile.
    How are you communicating if you aren't doing a pair request and waiting for a connection?  Then there are things like the 22 byte limit for reads.
    Sound to me that unless there are changes made to the sensor, you won't be able to use CIQ.
