Complete
WERETECH-12048
Fix will be applied to next SDK release.
Devices affected will have firmware updates in a future firmware build.
No more transparency for font background on bufferd bitmap since SDK 4.0
Hi,
I use a bufferedBitmap with color palette and custom bitmap fonts without antialiasing.
Since SDK 4.0 the font background  is not more transparent. The color is defined before:
dc.setColor(CustomColor, gfx.COLOR_TRANSPARENT);
The code is running many years without problem.
I don't understand, what's going wrong with new SDK
Parents
  • I have one watch face online, which is based on a transparent font background. It is AnalogSwitch Sports. With SDK 3.2 it shows normaly on a VA3 or fenix5/6:
    to safe energy the static elements are only write on watch face start or change settings to a buffered bitmap with palette of some colors. The right half circle is based not on a complete bitmap, then I can't change the color with settings, it is based on a custom font with all tiles of this half circle. So I can draw the buffered bitmap every minute and don't create the picture from tiles every minute.
    This is working since many years.
    With SDK 4.x it shows now:
    All tiles have loose the transparent background. I can't update the watchface anymore to support more new devices.
    thanks 2aCD
Comment
    thanks 2aCD
Children
  • To reproduce this sample is a little bit complex. But I have another sample, it is simple
    The digital time with this look is created with a dseg7 font, which is printed in white and then with offset 1px in black.
    This is only working with a transparent font background. For the always on second hand is a buffered bitmap created with palette.
                if (offscreenBuffer == null) {
                	offscreenBuffer = new Gfx.BufferedBitmap({
                    :width=> VA_Width-12,
                    :height=>VA_Height-12,
                    :palette=> [ProfileColors[0], ProfileColors[1], ProfileColors[2], ProfileColors[3],
                    			ProfileColors[8], ProfileColors[7], ProfileColors[9], Gfx.COLOR_GREEN,
                    			CustomColorHands, CustomColorHandsShadow, DigColor, DigColorShadow]
                	targetDc = offscreenBuffer.getDc();
    The colors are defined with different color profiles
    And this print the digitaltime string:
            if (DigitalTimeType == 3 && !ClassicHands && HideElements == 0) {  // some conditions to draw shadow
            	dc.setColor(DigColorShadow, Gfx.COLOR_TRANSPARENT);
            	dc.drawText(X-1, Y-1, fontDseg7, timeString, Gfx.TEXT_JUSTIFY_CENTER);
            dc.setColor(HideElements > 1? ProfileColors[1] : DigColor, Gfx.COLOR_TRANSPARENT);
            dc.drawText(X , Y, fontDseg7, timeString, Gfx.TEXT_JUSTIFY_CENTER);
    Have you a question, please give me a hint
    best regards
  • Hi, would you be able to share an example of the problem code? I can understand you may not want to share your entire project, but a code snippet involving the creation of the bufferedbitmap would be very helpful.
