Complete
I would recommend going to Connect Web forum and informing them of this issue.
Thanks!
Multisport activity's CIQ DF recorded fit data is not rendered on the website when switching tabs between the different sub-activities
I created this demo multisport activity (run, HIIT, strength), when each 3 used my CIQ DF that records some data to FIT:
https://connect.garmin.com/modern/activity/8973862272?share_unique_id=24
W
hen you open the link you'll see that there are 4 tabs: Multisport, Run, HIIT, Strength.
When you land on the above link you're in the Multisport tab, and you see a graph recorded by Connect IQ: ANT Heart Rate (bpm).
BUG 1: However when you change the tab to Multisport from any of the sub-activities' tabs, then the Connect IQ graph is not rendered any more.
The same is true for the Running tab: when you LAND on it using this link: https://connect.garmin.com/modern/activity/8973862272/1 (or open it in a new BROWSER tab/window using the icons in the web page) then you see both the Connect IQ graph and the Connect IQ stats.
BUG 2 & 3: However when you switch to the Running tab from any of the other tabs then neither the graph, nor the stats are displayed.
Possibly related to: https://forums.garmin.com/developer/connect-iq/i/bug-reports/hiit-and-strength-activity-doesn-t-display-all-the-recorded-fit-data
  • the 4 tabs:
    In Multisport you see the graph when you land for the 1st time:
    In Running you see the graph and the stats but only when you land for the 1st time (or you refresh the browser window):
    However you will see none of these when you switch from another tab
