Given the following JSON payload: {"foo": 42}
If makeWebRequest fetches that payload from outside a Media.SyncDelegate context, 42 is parsed as Lang.Number. However, if the makeWebRequest fetch is made within a Media.SyncDelegate context, it will be parsed as a Lang.Float.
This only occurs in CIQ 4.1.5. Previous versions don't exhibit this behavior.
LOGGING OUTPUT
- CIQ 4.1.5
Making request outside of SyncDelegate
responseCode=200 data={foo=>42}
[OK] saw a number
Making request inside of SyncDelegate.onStartSync()
responseCode=200 data={foo=>42.000000}
[FAIL] saw a float
[OK] saw a number
- CIQ 4.1.4
[OK] saw a number
[OK] saw a number
- CIQ 4.1.3
[OK] saw a number
[OK] saw a number
Example Code
// App.mc
import Toybox.Application;
import Toybox.Communications;
import Toybox.Lang;
import Toybox.Media;
import Toybox.System;
import Toybox.WatchUi;
class FloatJSONBugApp extends Application.AudioContentProviderApp {
var inFlight = false;
function initialize() {
AudioContentProviderApp.initialize();
// onStart() is called on application start up
function onStart(state as Dictionary?) as Void {
function makeRequest(msg) {
if (self.inFlight) {
return;
System.println(msg);
self.inFlight = true;
var url = "https://garmin-check-tls.s3.amazonaws.com/floatbug.json";
var parameters = {};
var options = {};
var responseCallback = self.method(:onResponse);
Communications.makeWebRequest(url, parameters, options, responseCallback);
function onResponse(responseCode, data) {
self.inFlight = false;
var msg = "responseCode=" + responseCode + " data=" + data;
if (responseCode != 200) {
return;
switch (data["foo"]) {
case instanceof Lang.Float:
System.println("[FAIL] saw a float");
break;
case instanceof Lang.Number:
System.println("[OK] saw a number");
break;
default:
System.println("[FAIL] saw other");
break;
// onStop() is called when your application is exiting
function onStop(state as Dictionary?) as Void {
// Get a Media.ContentDelegate for use by the system to get and iterate through media on the device
function getContentDelegate(arg as PersistableType) as ContentDelegate? {
return new FloatJSONBugContentDelegate();
// Get a delegate that communicates sync status to the system for syncing media content to the device
function getSyncDelegate() as SyncDelegate? {
return new FloatJSONBugSyncDelegate();
// Get the initial view for configuring playback
function getPlaybackConfigurationView() as Array<Views or InputDelegates>? {
self.makeRequest("Making request outside of SyncDelegate");
return [ new FloatJSONBugConfigurePlaybackView(), new FloatJSONBugConfigurePlaybackDelegate() ] as Array<Views or InputDelegates>;
// Get the initial view for configuring sync
function getSyncConfigurationView() as Array<Views or InputDelegates>? {
return [ new FloatJSONBugConfigureSyncView(), new FloatJSONBugConfigureSyncDelegate() ] as Array<Views or InputDelegates>;
function getApp() as FloatJSONBugApp {
return Application.getApp() as FloatJSONBugApp;
// SyncDelegate.mc
import Toybox.Lang;
class FloatJSONBugSyncDelegate extends Media.SyncDelegate {
SyncDelegate.initialize();
// Called when the system starts a sync of the app.
// The app should begin to download songs chosen in the configure
// sync view .
function onStartSync() as Void {
var app = Application.getApp();
app.makeRequest("Making request inside of SyncDelegate.onStartSync()");
Media.notifySyncComplete(null);
// Called by the system to determine if the app needs to be synced.
function isSyncNeeded() as Boolean {
return true;
// Called when the user chooses to cancel an active sync.
function onStopSync() as Void {
Communications.cancelAllRequests();
