Acknowledged
MapView and MapTrackView question
Hi
I want to ask a couple of questions about the behavior of MapView and MapTrackView.
I've searched the topics on the forum and there are some things written about MapView already, but none of them actually solves my issues.
1) setScreenVisible area doesn't seem to be working at all.
No matter what screen coordinates I specify it always shows up full screen both on the simulator and the real device (Oregon 700)
2) I want to handle key and touchscreen events in my own delegate class that inherits Ui.InputDelegate and does what it has to in the onKey() and onTap() functions.
It works all right in the simulator, but on the real device (Oregon 700) it behaves as if these events get handled by the underlying map application and hence never reach my code.
For example my intention is to use the tap screen event to have my own zoom control through the setMapVisibleArea function, that allows the application to "remember" the last used zoom level of the view and use it again when showing it the next time. Very simple to have a variable inside the view class with the current zoom level and change it by tapping the upper half or lower half of the map accordingly. This zoom level variable is afterwards used by setMapVisibleArea to determine the portion of the map shown around the current location.
As I've said, works in the simulator, but not on the device - there tapping on the screen puts the map directly into Preview mode by displaying an Info box with details about what's there on the map under the location the user has tapped etc. and the tap event never reaches the delegate class. This seems to be the default behavior of the map application on Oregon 700 and I haven't found a way to suppress it going to Preview mode.
The map behaves in a slightly different way when displayed in an activity. Then there's a dedicated button on the map's upper left corner (a dot with up, down, left, right arrows around it) which has to be pressed in order to put the map in Preview mode. It will not do it all by itself when just tapping somewhere on the screen. However that's the case only in an activity and not if one just launches the map application standalone (e.g. in classic mode) or when using the MapView and MapTrackView classes
I hope someone will be able to give me some tips and advice.
Thanks
Nick
Parents
  • That's the same conclusion that I also came to - it's behaving as if always in MAP_MODE_BROWSE as it allows panning etc. However there's obviously a second kind of behavior of the map because when it is invoked in an Activity it does not respond to tapping and swiping unless one deliberately hits the button on the upper left corner (dot with arrows in all directions) to enable the panning. Is there a way to configure the map application to be this way by default? I couldn't find such settings.  The second thing that doesn't feel quite right is the one I've described about buttons (selectables) placed on to of the map in the View. They can't get their clicking events because the underlying map intercepts the screen tap first. All input actions are intercepted by the map and not passed to the InputDelegate or BehaviorDelegate class paired with the View that contains the map.
Comment
Children
No Data
