var options = {
:resonseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_TEXT_PLAIN,
:headers => {
"Content-Type" => Communications.REQUEST_CONTENT_TYPE_URL_ENCODED
var params = {};
Communications.makeWebRequest(
"[URL here]",
params,
options,
method(:onReceive)
I'm trying to get some API data from URL https://apis.data.go.kr/B552584/MsrstnInfoInqireSvc/getNearbyMsrstnList
On simulator everything is fine (with responseType HTTP_RESPONSE_CONTENT_TYPE_TEXT_PLAIN, I can get 'SERVICE ERROR' xml text successfully from API server)
But when I sideload and run this widget on my Epix it doesn't work with responsecode -300 (NETWORK_REQUEST_TIMED_OUT)
It doesn't look like actual timeout since the responsecode comes out almost instantly(less than a second),
and with OpenWeatherMap API(https://api.openweathermap.org/data/2.5/air_pollution) everything worked fine.
I looked for similar cases to mine and found out there may be HTTP/HTTPS issue, or HTTPS with self-signed cetificate issue.
But I think those issues are not applicable to my case. (I'm using HTTPS with not self-signed certificate)
How can I get through?
PC OS : Win10
GCM Ver. : Android 4.60
Device : Epix Gen2 firmware 10.37(alpha)
SDK Ver. : 4.1.5
VS Code Ver. : 1.73
