Acknowledged
makeWebRequest fails on patreon audio content download
I'm getting error 0 when trying to download audio content from patreon servers on device (Fenix 7 Pro). It's working fine in the simulator, but not on device.
I've verified that it is a https url, and there shouldn't be any issues with the certificate, as the artwork (image) download just before succeeds.
The media encoding seems correct (mp3 file), and if I log the download url, it's valid for download on the computer later.
My request options look like this:
		var options = {
			:method => Communications.HTTP_REQUEST_METHOD_GET,
			:responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_AUDIO,
			:headers => {
				"Content-Type" => Communications.REQUEST_CONTENT_TYPE_URL_ENCODED,
			:mediaEncoding => Utils.mimeToEncoding(episode[Episode.MIME_TYPE]),
			:fileDownloadProgressCallback => method(:onDownloadProgress)
Out of respect for the content creator, I won't post the full content URLs here (but I can provide it to garmin representatives via DM for debugging), but they look like this (with redacted hashes):
The audio url, that fails on device:
https://c10.patreonusercontent.com/4/patreon-media/p/post/108392616/c302f7883bbc448eb2b32aaa3f4d5134/eyJhIjoxLCJwIjoxfQ%3D%3D/1.mp3?token-time=1725235200&token-hash=<hash-redacted>%3D
The image url that succeeds:
https://c10.patreonusercontent.com/4/patreon-media/p/campaign/8278829/b47426688d39440c9af3392914c867df/eyJoIjoxMDgwLCJ3IjoxMDgwfQ%3D%3D/2.png?token-time=2145916800&token-hash=<hash-redacted>%3D
Fetching the audio url from a computer with curl, the headers looks like this:
HTTP/2 200
date: Sun, 25 Aug 2024 09:21:48 GMT
content-type: audio/mpeg
content-length: 81094529
cf-ray: 8b8a83961a5e5f01-ARN
cf-cache-status: HIT
accept-ranges: bytes
access-control-allow-origin: https://www.patreon.com
cache-control: public, max-age=31536000
content-disposition: attachment; filename="Le Grifon 03; Too Many Stars.mp3"; filename*=utf-8''Le%20Grifon%2003%3B%20Too%20Many%20Stars.mp3
etag: W/4/patreon-media/p/post/108392616/<hash-redacted>%3D%3D/1
expires: Mon, 25 Aug 2025 09:21:48 GMT
vary: Accept-Encoding
access-control-allow-headers: Content-Type, Range, Content-Length
content-security-policy: default-src 'none'; media-src https://c10.patreonusercontent.com
x-powered-by: Express
set-cookie: __cf_bm=<hash-redacted> path=/; expires=Sun, 25-Aug-24 09:51:48 GMT; domain=.patreonusercontent.com; HttpOnly; Secure; SameSite=None
report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=<hash-redacted>%2F<hash-redacted>8%<hash-redacted>"}],"group":"cf-nel","max_age":604800}
nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
server: cloudflare
Been trying to speculate what might be the cause of the issue. Only theory I have so far is that the URL is very long (211 characters), and that might be the culprit?
  • That's some good investigation. Then it is indeed Garmin's SSL handling that is the issue here as well. Let's hope they can sort it out.
  • The makeImageRequest goes through Garmin servers, so the SSL negotiation will not be handled by the watch. The makeWebRequest on the other hand will be handled by the watch itself. I tested the domain on ssllabs, and it seems to provide an RSA certificate as well (next to an ec256 certificate). Although the Let's Encrypt RSA vs ECDSA issue solved a lot of problems, I also encountered the above error on a domain which has both RSA and EC256 certificates. Below you can find the cipher results from ssllabs from 2 different servers, where one succeeds and one fails:
    Test Server 1 Heavy check mark️
    # TLS 1.3 (suites in server-preferred order)
    TLS_AES_128_GCM_SHA256 (0x1301)   ECDH x25519 (eq. 3072 bits RSA)   FS 	128
    TLS_AES_256_GCM_SHA384 (0x1302)   ECDH x25519 (eq. 3072 bits RSA)   FS 	256
    TLS_CHACHA20_POLY1305_SHA256 (0x1303)   ECDH x25519 (eq. 3072 bits RSA)   FS 	256
    # TLS 1.2 (suites in server-preferred order)
    TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (0xc02f)   ECDH x25519 (eq. 3072 bits RSA)   FS 	128
    TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (0xc030)   ECDH x25519 (eq. 3072 bits RSA)   FS 	256
    TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256 (0xcca8)   ECDH x25519 (eq. 3072 bits RSA)   FS
    Test Server 2 X
    TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (0xc02b)   ECDH x25519 (eq. 3072 bits RSA)   FS 	128
    OLD_TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 (0xcc14)   ECDH x25519 (eq. 3072 bits RSA)   FS 	256P
    TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 (0xcca9)   ECDH x25519 (eq. 3072 bits RSA)   FS 	256P
    TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (0xc009)   ECDH x25519 (eq. 3072 bits RSA)   FS   WEAK 	128
    TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (0xc02c)   ECDH x25519 (eq. 3072 bits RSA)   FS 	256
    TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (0xc00a)   ECDH x25519 (eq. 3072 bits RSA)   FS   WEAK 	256
    TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 (0xc023)   ECDH x25519 (eq. 3072 bits RSA)   FS   WEAK 	128
    TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 (0xc024)   ECDH x25519 (eq. 3072 bits RSA)   FS   WEAK 	256
    OLD_TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256 (0xcc13)   ECDH x25519 (eq. 3072 bits RSA)   FS 	256P
    TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256 (0xcca8)   ECDH x25519 (eq. 3072 bits RSA)   FS 	256P
    TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (0xc013)   ECDH x25519 (eq. 3072 bits RSA)   FS   WEAK 	128
    TLS_RSA_WITH_AES_128_GCM_SHA256 (0x9c)   WEAK 	128
    TLS_RSA_WITH_AES_128_CBC_SHA (0x2f)   WEAK 	128
    TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (0xc014)   ECDH x25519 (eq. 3072 bits RSA)   FS   WEAK 	256
    TLS_RSA_WITH_AES_256_GCM_SHA384 (0x9d)   WEAK 	256
    TLS_RSA_WITH_AES_256_CBC_SHA (0x35)   WEAK 	256
    TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (0xc027)   ECDH x25519 (eq. 3072 bits RSA)   FS   WEAK 	128
    TLS_RSA_WITH_AES_128_CBC_SHA256 (0x3c)   WEAK 	128
    TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (0xc028)   ECDH x25519 (eq. 3072 bits RSA)   FS   WEAK 	256
    TLS_RSA_WITH_AES_256_CBC_SHA256 (0x3d)   WEAK
    Although all TLS1.2 ciphers from Test 1 are also in test 2, test server 2 still fails. For your server I found the following:
    # TLS 1.3 (server has no preference)
    TLS_RSA_WITH_AES_256_CBC_SHA256 (0x3d)   WEAK 	256
    Which looks a lot like my Test Server 2, but with some additional TLS1.3 ciphers. Maybe the 'only supports RSA' is not the full story here.
    I also tested whether RSA certificates still work on Test Server 2 (turn off ecdsa ciphers in about:config > search SSL3 > disable all except RSA). When browsing the url and checking the certificate, it changes to RSA properly.
