Environment
- Garmin Edge 1030+ (Software version: 6.75)
- Connect IQ SDK version: 6.4.2
- VS Code Extension version: v1.0.10
- VS Code version: 1.87.2
I'm implementing an oauth flow with the spotify api using the PKCE flow and running into a strange bug. The flow is made up of these steps:
- makeOauthRequest to accounts.spotify.com/authorize
- login via garmin connect mobile app in webview
- receive response code
- makeWebRequest to accounts.spotify.com/api/token to get access token
I previously implemented this flow using the non-PKCE flow (same steps, with slightly varied params) and it worked fine. UPDATE: I just re-built the old non-PKCE code and it no longer works as it's now suffering from the same redirect_uri override issue. I guess this implies something changed in the device firmware or Garmin Connect mobile app that introduced this bug?
The redirect_uri parameter that was used in the /authorize GET request needs to also be sent in the /api/token POST request and they need to match. The bug I'm running into is that despite using http://localhost as the redirect_uri value in both requests, the /api/token request in step 4 seems to have its redirect_uri param forcibly overridden with a value of gcm://oauth.
When I change the host value of the /api/token request to something else, the redirect_uri param is sent as expected with the http://localhost value, so it seems like something in the underlying http framework is getting cached around the accounts.spotify.com host.
Example /authorize call
var RedirectUri = "http://localhost"
var params = {
"client_id"=>$.ClientId,
"response_type"=>"code",
"scope"=>"user-modify-playback-state,user-read-playback-state,user-read-currently-playing,playlist-read-private,user-library-modify",
"redirect_uri"=>$.RedirectUri,
"state"=>_state,
"code_challenge_method"=>"S256",
"code_challenge"=>sanitizedChallenge
Comm.makeOAuthRequest(
"https://accounts.spotify.com/authorize",
params,
$.RedirectUri,
Comm.OAUTH_RESULT_TYPE_URL,
{"code"=>"code", "state"=>"state"}
Payload sniffed from garmin connect app
Example subsequent /api/token call with makeWebRequest, where redirect_uri gets overriden
Comm.makeWebRequest(
"http://accounts.spotify.com/api/token",
"code"=>accessCode,
"redirect_uri"=>"http://localhost",
"grant_type"=>"authorization_code",
"code_verifier"=>_codeVerifier
:method => Comm.HTTP_REQUEST_METHOD_POST,
:headers => {"Content-Type" => Communications.REQUEST_CONTENT_TYPE_URL_ENCODED}
method(:handleAccessResponse)
Payload sniffed from garmin connect app (notice that the redirect_uri in payload gets set to gcm://oauth despite it being set to http://localhost in the code)
