Ticket Created
WERETECH-12628
LocalMoment is wrong
The documentation fails to provide an initializing Constructor and the example is wrong.
a) It requires (where, when) not (when, where).
b) it doesn't take a Gregorian.moment as the when argument.
This, from the documentation fails:
if (Gregorian has :localMoment){
		var options = {
			:year   => 2018,
			:month  => 2,
			:day    => 24,
			:hour   => 0,
			:min    => 12
		var when = Gregorian.moment(options);
		var where = new Position.Location({
			:latitude  =>  38.85391,
			:longitude => -94.79630,
			:format    => :degrees,
		var local = Gregorian.localMoment(when, where);
		var info = Gregorian.info(local, Time.FORMAT_SHORT);
This works
		var options = {
			:year   => 2018,
			:month  => 2,
			:day    => 24,
			:hour   => 0,
			:min    => 12
		var local = Gregorian.localMoment(where, when.value());
- note (where, when), not (when, where) , and a number not a moment.
Parents
  • I just hit this bug for anyone wondering. Calling the API as per the docs crashes on device "unhandled exception". However calling value() as described above works fine. However, you have to do a disgusting trick like this to make the type checker happy:
    var z = m1.value() as Lang.Number or Time.Moment;
    var t1 = Time.Gregorian.localMoment(l1, z);
Comment
Children
No Data
