Acknowledged
Linux & SDKManager & simulator
Hi,
I know this has been discussed before, but did someone found a fix for the simulator not being launched in Linux when running  from VSCode? I know just Ubuntu distributions are supported. In my case I replaced Windows 10 by Zorin OS (based on Ubuntu), I can launch the sdk manager manually from the bin file and download the devices but when I run the 'Monkey C: Open SDK Manager' from VSC nothing happens. Curiously launching ERA Viewer from VSC works perfectly, why not the SDK manager? It just needs to know the path and run the file.
I also found out that if first I open the simulator using the file in the sdk path and then launch the run of the watchface using VSC the watchface is run in the simulator. Has anyone found a fix to this problem?
Thank you
Parents Comment Children
