Complete
WERETECH-8515, VVA4-4657
This is fixed as of the 4.50 firmware release for vivoactive 4.
latest fw update on VA4 killed behaviorDelegate
My app NASA PoD was working just fine on a number of devices and in the simulator.  I just updated my VA4 firmware (4.00, GPS 2.7) and the widget no longer scrolls within the text display using behaviorDelegate.  I tried a few things and it still does not work on the actual device.
class TextViewDelegate extends Ui.BehaviorDelegate {
    var isTouchScreen;
    function initialize() {
        BehaviorDelegate.initialize();
        isTouchScreen=Sys.getDeviceSettings().isTouchScreen;
        isTouchScreen=false; //override in attempt to fix VA4 bug
    function onBack() {
        //Sys.println("onBack");
        Ui.popView(Ui.SLIDE_IMMEDIATE);
        return true;
    function onNextMode() {
        //Sys.println("nextMode");
        return onNextPage();
    function onNextPage() { // scroll down
        //Sys.println("next");
        if(!isTouchScreen) {
            scroll(:UP);
            return true;
        return false;
    function onPreviousMode() {
        return onPreviousPage();
    function onPreviousPage() { //scroll up
        //Sys.println("prev");
            scroll(:DOWN);
            return true;
        return false;
    function onSwipe(evt) {
        var dir=evt.getDirection();
        //Sys.println("swipe: "+dir);
        if(dir == Ui.SWIPE_UP) {
            scroll(:UP);
            return true;
        if(dir == Ui.SWIPE_DOWN) {
            scroll(:DOWN);
            return true;
        return false;
    function onHold(evt) {
        var coor = evt.getCoordinates();
        //Sys.println("onHold"+coor[0]+", "+coor[1]);
        return false;
Parents
  • I think you are too good to be in Garmin development team. The have 0 QA, 0 developer support and 0 responsibility to fix actual bugs. If I had a bug severe as this, I would deploy a hot fix in 24 hours or at least revert the current version.
    I really consider to switch to Galaxy Active 2, what do you think about it?
Comment
Children
  • Understand that if the FW is involved (That seems to be the case here), Garmin has release cycles for that, so fixes come in the next release.  I know it's frustrating and I've seen it a number of times over the last 5 years.  Garmin doesn't just release a fw "hot fix" in a couple days.
    In the past, when this happens, I've sometimes just removed the impacted device as a target for the app until there is a fix.  It cuts down on bad reviews and frustrated users.  Another thing to consider is re-working your app so it doesn't use onNext/onPrev to change pages - maybe KEY_ENTER instead.  Or change pages every x seconds based on a timer - a work around until a fix has been released.
    I've met most of the CIQ developers and SQ folks (all up through the last Summit).  Trust me.  Things like this frustrate them too.
