Acknowledged
keyEvent.getKey() == 4 short vrs long pressed
Hi! I have the following problem, you might know the reason/solution.
I have the following code line:  if (keyEvent.getKey() == 4) {onSelect_lauch();}
I found that, in the simulator, for several devices, when I press the "Start-Stop buttom" (Key 4), if I press it long (not just one click but a "long" click), it launches properly the function but if I press it short, I gives me the typical error "Symbol Not found Error". It is an App (not a widget).
Error: Symbol Not Found Error
Details: Failed invoking <symbol>
Stack:
Do you know why and how to solve it?
Thanks!
Parents
  • I am using the Forerunner 645m, but happens the same in several devices. What do you mean with "to return a value in your onKey function"?
    If I do:
    function onKey(keyEvent) {
            if (keyEvent.getKey() == 13) {slide_left();}
            if (keyEvent.getKey() == WatchUi.KEY_ENTER) {onSelect_Battle();}
    public function onSelect_Battle() as Boolean {
            System.println("Activated")
            return true;
    It works well with "long" and "short" press. I do not know why with if (keyEvent.getKey() == WatchUi.KEY_ENTER) {onSelect_Battle();} it does not work with short press.
    If istead of KEY_ENTER ( number 4) I use aother button, the 13 for example it works perfect, but I need to use the 4 (key_Enter).
    Might be the sim that is not working properly?
    Thanks!
Comment
    If I do:
            return true;
    Thanks!
Children
No Data
