Acknowledged
keyEvent.getKey() == 4 short vrs long pressed
Hi! I have the following problem, you might know the reason/solution.
I have the following code line:  if (keyEvent.getKey() == 4) {onSelect_lauch();}
I found that, in the simulator, for several devices, when I press the "Start-Stop buttom" (Key 4), if I press it long (not just one click but a "long" click), it launches properly the function but if I press it short, I gives me the typical error "Symbol Not found Error". It is an App (not a widget).
Error: Symbol Not Found Error
Details: Failed invoking <symbol>
Stack:
Do you know why and how to solve it?
Thanks!
Parents
  • Thanks your your reply. However, this does not seem to be the problem. I tried with your code and still not working...the problem is the duration the buttom button 4 is pressed. If pressed just once, quick, does not work, if pressed once long (push, wait, release) it works...
Comment
Children
No Data
