Ticket Created
CIQQA-864
java.lang.NullPointerException while compiling on Kubuntu 21.10 with newer SDK's
This is some issue I experience for some time. Atm, I use Kubuntu 21.10 but I had it in previous versions too. First I need to search and install many packages due to old Ubuntu dependencies. Later I install Eclipse, plugin, SDK etc. SDK 3.1.9 works fine and I can compile and run an app from Eclipse. However, it's old and it doesn't support lots of newer devices. So I install any later SDK via SDK manager and install all the devices. However, it doesn't compile then. I tried Visual Studio Code instead of Eclipse and also tried to run the command inside the terminal. I only got a NullPointerException with some DevicesJsonReader.java file.
A try with a watchface sample named DenemeVC:
Executing task in folder DenemeVC: /home/sis651/JAVA/jre1.8.0_311/bin/java -Xms1g -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar /home/sis651/.Garmin/ConnectIQ/Sdks/connectiq-sdk-lin-4.0.7-2021-11-29-437ff4cc4/bin/monkeybrains.jar -o /home/sis651/DEV/workspace/DenemeVC/DenemeVC.prg -f /home/sis651/DEV/workspace/DenemeVC/monkey.jungle -y /home/sis651/DEV/ConnectIQSDK/developer_key.der -w -d d2charlie -r <
ERROR: null
at com.garmin.connectiq.common.devices.DevicesJsonReader.parseResolution(DevicesJsonReader.java:584)
at com.garmin.connectiq.common.devices.DevicesJsonReader.loadDeviceFromElement(DevicesJsonReader.java:398)
at com.garmin.connectiq.common.devices.DevicesJsonReader.read(DevicesJsonReader.java:321)
at com.garmin.connectiq.common.devices.DevicesJsonReader.read(DevicesJsonReader.java:304)
at com.garmin.connectiq.common.devices.DevicesJsonReader.read(DevicesJsonReader.java:302)
at com.garmin.monkeybrains.devices.DeviceManager.readStreamIntoDevicesJsonReader(DeviceManager.java:48)
at com.garmin.monkeybrains.devices.DeviceManager.<init>(DeviceManager.java:71)
at com.garmin.monkeybrains.Monkeybrains.loadDeviceManager(Monkeybrains.java:438)
at com.garmin.monkeybrains.Monkeybrains.run(Monkeybrains.java:2490)
at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:339)
at com.garmin.monkeybrains.Monkeybrains.main(Monkeybrains.java:368)
usage: monkeyc [-a <arg>] [-b <arg>] [-c <arg>] [-d <arg>] [-e]
[--Eno-invalid-symbol] [-f <arg>] [-g] [-h] [-i <arg>] [-l <arg>] [-m
<arg>] [-o <arg>] [-p <arg>] [-r] [-s <arg>] [-t] [-u <arg>] [-v] [-w]
[-x <arg>] [-y <arg>] [-z <arg>]...
I had tried to dig it a bit more and I remember it was about something like sizeKey is missing somewhere. 3.1.9 works fine, but anything later results in the same NullPointerException. It happens with all my apps and devices I choose.
Anyone has an idea?
Parents Comment Children
  • Yes, they're up to date. Also I had tried this in a previous setup, and it was the same. It's like it can't parse the device json files. However, 3.1.9 and previous SDK's had the all device properties and they work normally. I tried OpenJDK and Oracle JDK; both results in the same.
    Maybe I'll try to run it in wine, like I did years ago. Or I'll install a Windows to a VirtualBox and try with it.
