Ticket Created
CIQQA-1278
Issues with the simulator playback of GPX data.
I have just discovered the ability to playback a GPX file that was introduced but not announced ("Add support for new FIT simulation and playback dialog.") in Beta 4.1.0
This is a very valuable feature for me, and with a bit of tweaking, I have made it work.
There are a few issues.
  1. It fails to copy the chosen GPX file into the folder /var/folders/ly/qnh242bx7z98fz51w0yvjvjm0000gn/T/GARMIN because GARMIN does not exist in ..../T/. When manually created, it proceeds OK.
  2. position.Info.speed always reports 0.00 This is a bug. (unable to post screenshot) :
    positionInfo
    Lang.Object
    accuracy: 4 (Lang.Number)
    altitude: -499.99445 (Lang.Float)
    heading: -0.77554625 (Lang.Float)
    position: Lang.Object
    speed: 0.0 (Lang.Float)
    when: Lang.Object
  3. The timestamps, which are mandatory in GPX<trkpt> syntax, are ignored, so the playback occurs in real-time, not those in the GPX file.
  4. (the altitude is reporting -499.99.. , but since I'm sailing I don't care about altitude!)
  5. It would be immensely valuable if the speed of the replay could be controlled from the playback dialog.
