Ticket Created
CIQQA-523
Issue with App Settings Editor when opened from File menu in simulator window (not from IQ Connect menu in Eclipse)
I'm just realizing that opening the App Settings Editor from the simulator is different from opening it up from the Connect IQ menu in Eclipse.  When I change settings after opening the editor directly in Eclipse, everything works as expected.  When I open the editor from the simulator, listEntry values are ignored.
For example with this setting defined:
<setting propertyKey="@Properties.sport_prop" title="@Strings.lbl_sport">
    <settingConfig type="list" >
    	<listEntry value="0x0100">@Strings.lbl_running</listEntry>
    	<listEntry value="0x0500">@Strings.lbl_swimming</listEntry>
    </settingConfig>
</setting>
Selecting the first item would update the corresponding app setting to 0x0100 if done by opening the editor from Eclipse and to 0 if done from the simulator.
I'm running simulator version 4.0.3
Also, numeric settings are edited with a text box (rather than a numeric up/down box, which is what I get when opening the editor from Eclipse).
Parents Comment Children
