Acknowledged
CIQQA-3124
Instinct E / Instinct 3 Solar, sim: simple data field value is right-aligned / truncated for top field, in 3 Field Layout A
For the same field, the label is properly centred, as are all the labels and values for all other layouts.
See comment for screenshots.
  • > simple data field value is right-aligned / truncated for top field, in 3 Field A layout
    To be clear, what's probably actually happening is that the value is simply misaligned with the label.
    This can be seen from the field definition in simulator.json
    // first/top field for 3 Field A, instinct3solar45mm (broken)
        "data": {
            "font": "numberMedium",
            "justification": "center",
            "width": 95,
            "x": 94,
            "y": 57
        "label": {
            "font": "xtiny",
            "x": 64,
            "y": 18
    The x value for the label is very far from the x value for the field value. For other layouts/fields, the x values are similar.
    // first/top field for 3 Field A, instinct2 (good)
        "data": {
            "font": "numberHot",
            "width": 80,
            "x": 51,
            "y": 50
        "label": {
            "font": "xtiny",
            "x": 61,
            "y": 19
  • Also, the corresponding 4 Field A Layout in instinct 2 looks fine:
  • SDK 8.1.1, device files current as of 2025-04-08 14:21 UTC-0400
  • Though this is probably only the simulator.json of the device, but for future reference: SDK?
