Acknowledged
CIQQA-3588
Instinct 3 Solar stuck in high power mode
Firmware version:
This has been reported with 10.36, but not with 9.21
Software affected:
Any Connect IQ watch face, including Garmin's ones
Expected behavior:
1. When wrist is raised (watch facing up), watch enters 'high power mode' (onExitSleep() is called, then onUpdate() is called every second)
2. After about 10 seconds, watch automatically enters 'low power mode' (onEnterSleep() is called, then onUpdate() is called every minute)
Actual behavior:
1. When wrist is raised, watch enters 'high power mode'
2. Watch remains in 'high power mode', automatic switch back to 'low power mode' does not occur
3. Watch enters 'low power mode' only after wrist has been lowered (watch facing down)
Impact and severity:
This causes significant excessive battery drain (reportedly up to 100% increase) in Connect IQ watch faces and it can't be worked around by the watch face developer.
Supporting information:
A user report posted here https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/instinct-3/423711/infinite-gesture-on-issue-on-instinct-3-solar-firmware-problem
Parents
  • And for me, the most used dials are unusable because they consume electricity like a llama. And the sensor is really very sensitive, at the slightest movement the screen lights up. I hope they fix it in the next update.
Comment
Children
No Data
